EBCM compatibility ?????? have you swapped modules??
Old Dec 3, 2012 | 10:01 PM
m88vet's Avatar
m88vet
From: LA from the 6th sept till the 10th sept california ( then New Zealand)
Default EBCM compatibility ?????? have you swapped modules??
OK... Need an 100% answer on this and no guesses please..!!
Does a 2003-2004 EBCM Abs module work 100% with no codes on a 2001-2002 vette ?
If not , why not??
anyone using a 03 04 ebcm on a 2001 or 2002?
Old Dec 4, 2012 | 01:23 AM
m88vet's Avatar
m88vet
bump....
Old Dec 4, 2012 | 03:31 PM
m88vet's Avatar
m88vet
ttt
Old Dec 4, 2012 | 03:44 PM
m88vet's Avatar
m88vet
is it a software thing hence the SB or SF etc stickers? anyone?
Old Dec 4, 2012 | 06:41 PM
m88vet's Avatar
m88vet
ttt
Old Dec 5, 2012 | 02:50 PM
m88vet's Avatar
m88vet
ttt
Old Dec 5, 2012 | 04:03 PM
3boystoys's Avatar
3boystoys
Think it depends on if the car had AH or not.
Old Dec 5, 2012 | 04:09 PM
m88vet's Avatar
m88vet
ah didnt think of that, but don't all 2001 up have active handling?? thanks for your input....
Old Dec 5, 2012 | 04:47 PM
BigGun's Avatar
BigGun
Yes, they do.
Old Dec 5, 2012 | 05:12 PM
01vetter's Avatar
01vetter
First time I have heard of an incompatibility in 2001-2004 EBCMS. I thought they were all the same. 1997 to 2000 not compatible.
Old Dec 7, 2012 | 12:04 AM
m88vet's Avatar
m88vet
thanks for that!
Old Dec 7, 2012 | 06:05 PM
m88vet's Avatar
m88vet
Is there any way ( other than its toast ) that when i plugged my suspect module into a fully functional 2003 ( my ebcm is an 02 ) it would show NO COMM for any other reason than its screwed? i did not bolt it into place just plugged it in. i figured that the 2 grounds on the plug would be ok for the circuit , as it has rubber mounts.
anyone chime in??? As i say speedo repair guy says module is good . SO HOW CAN I HAVE NO COMM with that module on another corvette and mine!!!!! ???? do you trust these module fixers??
HELP!
Old Dec 8, 2012 | 02:27 PM
01vetter's Avatar
01vetter
Do a search on No COMM. There are plenty of posts about this. Could be a connector, wiring or ground problem. The connector has many pins. Inspect them for bent pins and/or corrosion/dirt. Also inspect the wiring for any breaks. And check the fuses.
Old Dec 9, 2012 | 04:44 PM
BigGun's Avatar
BigGun
HELP!
Since your getting no comm of both cars I would say it's your module. Check the pins closely on the module. I have no idea if they are compatible so that could be an issue also. Have you checked part numbers to see if they are different between years? How did the module guy check it without plugging it into a Corvette? Very unlikely.
Old Dec 9, 2012 | 05:29 PM
m88vet's Avatar
m88vet
thanks pins are all good etc etc ... yeah thats what i thought ..... But it seems Acdelco sell them for 01 02 (part no 12216561) then 03 04 (10343433) !! also the 01 - 02 are more expensive! check out www.acdelcodirect.com
as the 03 04's are 150 bucks cheaper i thought i would buy one of them. Any advice?? i have started a thread about the compatibility of the 01 -04 . but no 100% answers yet!! some one must know!!
Old Dec 9, 2012 | 05:35 PM
BigGun's Avatar
BigGun
Different part numbers, different price, = different parts.
Old Dec 10, 2012 | 07:38 PM
m88vet's Avatar
m88vet
Ok yep so we know diff part numbers for the ebcms. But what i am trying to work out is. If the EBCM units are not compatible from 01-02 on a 03 04 .... then maybe this is why i still get a NO COMM because the vette i used to plug in the EBCM was an 03 . ( mine is an 02 ) SPeedoguy says my module is good , even though i have my doubts. I dont want to spend $800 on a new module only to find that my module was good all along. hope i make sense
It seems 50% of people think you can use any 01-04 module and the other 50% say NO
I just need a definitive answer to put this to bed !! any vendors or experts please chime in...
To EBCM compatibility ?????? have you swapped modules??
Old Dec 10, 2012 | 07:40 PM
lionelhutz's Avatar
lionelhutz
I'd bet money that any year C5 module would communicate when connected to any year C5 car.
Old Dec 11, 2012 | 05:12 PM
m88vet's Avatar
m88vet
yep i tend to agree.... abs fixer says all the same, zip corvette lists 01 04 ebcm as the same. others dont
Old Dec 11, 2012 | 05:13 PM
m88vet's Avatar
m88vet
any one using a 03 04 module on an 01 02?? or visa versa??
come on someone must have done this swap!!
