Wheel size an offset question need help
Old Dec 6, 2012 | 06:27 PM
hockykng9's Avatar
hockykng9
Default Wheel size an offset question need help
Was going to order c6 z06 hypersilver wheels I was originally going to get 18x8.5 with +56 offset but instead I want 18x9.5 with a +50 offset with the 18x9.5 in the front will I have any clearance problems with steering and it rubbing the wheel well..an if not i was going to lower it will it still clear the front wheel wells when turning
Old Dec 6, 2012 | 06:35 PM
dblerman's Avatar
dblerman
You'll be fine. That's not much different that stock Z06 width and offset.
Old Dec 6, 2012 | 07:02 PM
hockykng9's Avatar
hockykng9
Even though I have a 99 it will be ok with the clearance
Old Dec 6, 2012 | 09:04 PM
dblerman's Avatar
dblerman
Yes. All year C5s are the same. You can interchange any year with any year.
Old Dec 6, 2012 | 09:26 PM
hockykng9's Avatar
hockykng9
any tire size recommendations i was going to do 245/40-18x8.5 or 9.5 depending on my choice for the fronts and 275/30-19x10 for the rear an other choices recommendations on tire size?
Old Dec 6, 2012 | 10:32 PM
dblerman's Avatar
dblerman
275/35 front and 285/35 rear is what i run on my 18x9.5 + 19x10 rims. These are very close to stock diameter and wont cause any traction control/active handling issues.
a 245 is WAY narrow for a 9.5" width. And a 245/40 would have a larger overall diameter than a 275/30...that combination does not work. You need your front wheels to have a diameter AT LEAST .5 smaller than your rear wheels. Also, the diameter of your rear wheels can not be more than 1.5" larger than your front.
Old Dec 7, 2012 | 04:20 PM
hockykng9's Avatar
hockykng9
so you run 275/35 front and 285/35 rear is there going to be a speedometer difference im i going to need to get my speedo recalibrated? with those sizes
Old Dec 7, 2012 | 04:35 PM
dblerman's Avatar
dblerman
No. You will be fine.
Old Dec 7, 2012 | 06:18 PM
hockykng9's Avatar
hockykng9
thanks! because i heard i may need a retune to reset the speedo an i went on a tire size calculator site and put the 275/35 front and 285/35 rear and it says theres a 4.77% Diameter difference and the speed for the fronts said rolling at 60mph and the rear said it would be 57.1 and there saying thats a 5% difference i didnt no if that was ok or not.What brand tires are you running with your wheels
Old Dec 7, 2012 | 07:00 PM
dblerman's Avatar
dblerman
No. The difference between your FACTORY 245/45 front tire diameter and the NEW 275/35 front tires is 0.43%. The difference between FACTORY 275/40 rear tire diameter and NEW 285/35 rear tires is 0.71%. Your speedometer will be off by less than 0.5 MPH.
Old Dec 7, 2012 | 07:14 PM
hockykng9's Avatar
hockykng9
and what brand tires are you using on your car if you dont mind me asking?
Old Dec 7, 2012 | 07:18 PM
dblerman's Avatar
dblerman
Hankook Ventus V12. They're an amazing tire, HIGHLY recommended here on the forum with lots of guys running them, and the price is great.
Old Dec 7, 2012 | 07:32 PM
hockykng9's Avatar
hockykng9
i will look into that did you order those tires online or through a local dealer? looking for a good price is all how much did these run you? sorry for all the questions
Old Dec 7, 2012 | 07:49 PM
dblerman's Avatar
dblerman
I got them from tirerack.com last year, they were going around $1100 then. Now tirerack has them for $850.
Old Dec 7, 2012 | 08:34 PM
hockykng9's Avatar
hockykng9
For all 4?
Old Dec 7, 2012 | 08:45 PM
dblerman's Avatar
dblerman
Yes.
Old Dec 7, 2012 | 09:02 PM
hockykng9's Avatar
hockykng9
Thanks I appreciate the help!
Old Dec 8, 2012 | 05:23 AM
tomlink's Avatar
tomlink
Just added 18x9.5/+57mm with 275/35 on the fronts and 19x11/+64mm with 305/30 in the rear on my C5. No rubbing and the handling is night and day from stock. C6 Z06 replicas (original style 10-spoke). No problems with computer or noticeable difference in speedo. Go as big as you can, you'll love it.
To Wheel size an offset question need help
