Help disconnecting EBCM please!
Old Dec 6, 2012 | 08:29 PM
Kale's Avatar
Kale
Default Help disconnecting EBCM please!
From ABSfixer:
3 - Remove the wire harness by first removing the white plastic clip that locks it in place, then lift gray handle and pull back on the wire harness. At this point, you will be able to see the second wire connection that is removed by pulling down.
I don't have any such handle.
That's probably the handle he's talkign about.
My car doesn't have that.
Old Dec 6, 2012 | 08:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Someone broke or took it off. It just inserts and retracts the connector straight and square. If you dont have it, just pull the connector straight off and install it straight on.
Old Dec 6, 2012 | 08:41 PM
Kale's Avatar
Kale
Thanks Bill.
This old GM plastic is very brittle.. didn't want to crack it apart!
Old Dec 6, 2012 | 11:09 PM
Chicago1's Avatar
Chicago1
Hopefully the unit pulls out from the other one. Mine was a beast to get out. Wiggle it free with a flat head is my advice.
Old Dec 7, 2012 | 12:06 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Originally Posted by Kale
Thanks Bill.
try wrapping the plastic with duct tape real tight first....
To Help disconnecting EBCM please!
