Tire Pressure Question
Old Dec 7, 2012 | 08:36 PM
97VetteDan's Avatar
97VetteDan
Default Tire Pressure Question
I've got 285/40ZR18 101w Extreme ZR's in the rear and 255/40ZR17 94y FK 452's in the front. Can someone tell me the correct tire pressure for the front and rear? Thanks!
dblerman's Avatar
dblerman
30psi.
Just like it says in the owners manual and door tag.
Old Dec 7, 2012 | 11:52 PM
m6 c5's Avatar
m6 c5
30 psi cold is going to give you a fairly good wear pattern, if you want to nail it down for your specific tire your best bet would be to get a temp gun and take readings of the inside, middle and outside of the tire and adjust up and down until all readings are the same after a nice drive.
Old Dec 8, 2012 | 10:07 AM
jrose7004's Avatar
jrose7004
30 psi cold.
To Tire Pressure Question
