Head Lights actuator noise
Old 12-10-2012, 04:33 PM
nnicholas
Support Corvetteforum!
nnicholas's Avatar
Default Head Lights actuator noise
When I turn on my head light, they pop up fine. When I turn them off there is a loud noise for about 6 seconds and then they go down. Is the actuator bad or can it be lubricated?
Nick
Old 12-10-2012, 09:05 PM
corvette77
corvette77's Avatar
Your headlight gear is stripped. This is a very common problem. Buy a brass gear and replace it.
Old 12-11-2012, 07:59 AM
nnicholas
nnicholas's Avatar
Thanks, I ordered two last night. The forum gave me instructions on how to replace the gear as well. What a great site. Thanks for getting back with me.
Nick
Old 12-11-2012, 08:00 AM
nnicholas
nnicholas's Avatar
Nice ride as well
Old 12-12-2012, 10:06 AM
Joevette99
Joevette99's Avatar
Pretty straight forward repair. Did mine two weeks ago...easier on '97-99 cars as the gears are held in place by a cover with three screws. New models require prying the cover off and resealing.
If you have the older model, plastic gears and the rubber insert is the cheaper way to go, original plastic gear lasted 13 years. If you have to epoxy the cover closed (newer models), go with the brass gears and never worry about it again.
Really really easy repair to perform. Just need relatively thin arms to unbolt the headlight housing.....
Old 12-12-2012, 03:57 PM
nnicholas
nnicholas's Avatar
Thanks, have a 2001 convertible. My hands are XXL, I will ask my neighbor to help when I get to that point. Did you have to manually raise the head lights first?
Old 12-12-2012, 03:59 PM
nnicholas
nnicholas's Avatar
I also ordered two gears for when the driver side goes out. Any suggestions for a good quick setting epoxy for the cover
Old 12-12-2012, 05:33 PM
Big_George_S
Big_George_S's Avatar
Mine came in the kit with the gears. Good luck.
Old 12-12-2012, 10:16 PM
corvette77
corvette77's Avatar
Nice ride as well
Thanks!
I made sure to let mine cure for 24 hours before assembling it back on the car.
Old 08-19-2013, 09:21 PM
jpulone
jpulone's Avatar
I saw a procedure for removing the entire head light assy., not just the motor but can't find it again. Can someone give my a link to that procedure?
Old 08-20-2013, 06:22 AM
nnicholas
nnicholas's Avatar
Are you having issues with head light noise (gear stripped out)? I replaced the stripped gear in my motor housing last winter and noticed that only 1/2 the gear is being used to raise and lower the head lights. Before going all the way with taking out the head light, motor, etc. try removing the bolt connecting the actuator arm that raised and lowers the head light. Then manually rotate the gear 180 degrees and bolt the arm back to the actuator. You will now be using the other half of the gear inside the motor. You can do this until your new gears arrive....
Old 08-20-2013, 06:35 AM
Cybermind
Cybermind's Avatar
Best rebuild kit you can get is from Rodney Dickman. I highly recommend his kit. I did mine two weeks ago and everything in the kit was very high quality including the special two part adhesive which set in about 10 minutes. He also includes a unique T-brace which no one else has. This brace goes over the cover upon re-assembly and provides a better load bearing point for the gear shaft. It also ensures that the cover does not come apart. I did both my actuators and they are now as smooth as butter and I don't ever need to worry about them again.
Long live the pop-ups!!!
To Head Lights actuator noise
Quick Reply: Head Lights actuator noise
