Security codes, car will not start
Old Dec 11, 2012 | 03:13 AM
Abnmarine's Avatar
Abnmarine
Default Security codes, car will not start
Been reading a lot of posts for solutions of the ignition security. This is the first time it's happened. I've cleaned the key, electrical cleaner in the ignition, checked the fuses, ignition and BSM connections. Engine will not turn over. Security issues. Codes displayed are:
P1631
C1287
B2721
B2722
B2723
Key initially was hard to insert. Tried clearing the codes but the B codes instantly return. Battery is good. I've read about wiring a resistor to over ride the security. I've measures my key chip and its 4.69 ohms.
Tomorrow I will have my spare key cut (its a chipped blank now), if that doesn't help, looks like its the ignition.
It's frustrating since its currently parked in a parking lot.
Any other tips to get the car home?
Old Dec 11, 2012 | 12:53 PM
Abnmarine's Avatar
Abnmarine
Anyone?
Does it sound like I'm on track for correcting this? Does anyone have a picture of where the resistor can be wired in to bypass the security?
Old Dec 11, 2012 | 04:13 PM
1999_TRC's Avatar
1999_TRC
That is not possible, unless the pellet is shorted. Are you sure you are reading on the correct scale?
Old Dec 11, 2012 | 04:59 PM
Abnmarine's Avatar
Abnmarine
I thought I was. I set my meter on ohms and placed a lead on each contact of the chip. Am I doing something wrong?
Old Dec 11, 2012 | 08:07 PM
Abnmarine's Avatar
Abnmarine
I just had my spare key cut. Locksmith tested both and they are good. They are #13 keys BTW. He recommends me to use a multimeter on the ignition wire for the resistor. If no continuity with the key in, then the ignition is bad. If continuity, it's elsewhere.
Old Dec 11, 2012 | 08:16 PM
1999_TRC's Avatar
1999_TRC
I just went through this a year ago. Your resistance measurement(or meter) are way off. First I thought you might have had it on the wrong scale, but now you know it could not be right(based on it being a #13 key), no matter where you move the decimal point. You need to measure resistance, NOT continuity. If the resistance reading is not between 7200-7820 ohms, then the lock cylinder is bad, NOT the ignition switch itself.
Old Dec 11, 2012 | 09:28 PM
Abnmarine's Avatar
Abnmarine
Okay, I just measured the key resister again. Measured 7.48 which would be 7480 ohms and within tolerance. I disconnected the resistor wires from the ignition, inserted the key with ignition on and also tried it off. No measurement provided. I feel confident the ignition switch is bad.
Does this sound correct?
Old Dec 11, 2012 | 11:17 PM
1999_TRC's Avatar
1999_TRC
No, as I already stated in my previous post, that points to the lock cylinder NOT the ignition switch.
Old Dec 11, 2012 | 11:30 PM
Abnmarine's Avatar
Abnmarine
Lock mechanism is what I meant. I just bought some resistors and I'm gonna give that a try. I should have an answer in an hour.
Old Dec 12, 2012 | 12:06 AM
Abnmarine's Avatar
Abnmarine
After wiring the resistors in series they measured 7400. I installed it and the car started. I'm stoked!
I avoid dealerships but they wanted over $800 and its now fixed with $5. This forum was a huge help.
Old Dec 12, 2012 | 07:26 AM
runner140*'s Avatar
runner140*
Its a great day when we can cheat the dealership out of a visit.
To Security codes, car will not start
