TAC module connector pin out
Old Dec 14, 2012 | 06:49 AM
Torch2000FRC's Avatar
Torch2000FRC
Default TAC module connector pin out
I am looking for the tac module connector pinout mainly for the 3 primary Tps signal wires and the 4 iac wires car is an 01 Z06 should be same as base thank you
Old Dec 14, 2012 | 07:24 AM
1999_TRC's Avatar
1999_TRC
No IAC on a C5. This should point you in the right direction.
http://forums.corvetteforum.com/1569928039-post5.html
Old Dec 14, 2012 | 07:35 AM
Torch2000FRC
I was meaning the circuit for idle sorry I am converting to drive by cable and need to find the wires for the idle circuit or it may be called throttle actuator motor control, this diagram is for the cruise control and app sensor
Old Dec 14, 2012 | 07:55 AM
1999_TRC's Avatar
1999_TRC
I was meaning the circuit for idle sorry I am converting to drive by cable and need to find the wires for the idle circuit or may be called tac circuit
Good luck with that.
Old Dec 14, 2012 | 08:56 AM
Torch2000FRC
Pretty much found Tps tac diagram but can't find a diagram for for tac motor function I well ill just pin it myself for the iac thanks for the help anyways man
To TAC module connector pin out
