6.2l questions
Old Dec 15, 2012 | 10:53 AM
safariowner's Avatar
safariowner
Cruising
Default 6.2l questions
im curious does the ls3 6.2 have cylinder cut off for mpg?
im here for resurch purposes
Old Dec 15, 2012 | 11:42 AM
7LitreC5's Avatar
7LitreC5
No it does not.
Old Dec 15, 2012 | 11:55 AM
safariowner
Cruising
what years and models had the 6.2, whats the vin code?
Old Dec 15, 2012 | 12:04 PM
7LitreC5's Avatar
7LitreC5
The 6.2 started in the 2008 model year and is currently still the only engine available in the standard C6 and the Grand Sport.
The ZR1 engine is also a 6.2. I assume that this is not what you are referring to.
Old Dec 15, 2012 | 12:09 PM
safariowner
Cruising
that is what i am referring to ironically, ik that they have a big block but i need A small block and 6.2 is exactly what i want
Old Dec 15, 2012 | 01:57 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
The AFM or DOD system is not used on the C6---Only on trucks--
However if you've been reading about the NEW 6.2 that GM has annnounced for the C7's
It will incorporate the AFM/DOD system to meet the new CAFE MPG requirements
The C7 will have apprx 450 HP and is a total re-design
In addition to DOD it will have variable valve timing and "Direct Port Injection" which is a whole new direction for Corvettes--2000-3000 lb fuel pressure !!!! cam driven hi pressure fuel pump -----11.5-1 compression !!!
Old Dec 16, 2012 | 06:28 PM
safariowner
Cruising
thanks a lot! do u know if these are drive by wire or any 6.2 car is?
Old Dec 16, 2012 | 06:38 PM
PhilsFRC's Avatar
PhilsFRC
C7 LT1 engine. Go to the C7 board-lots of discussion on the motor.
Old Dec 17, 2012 | 12:19 AM
C5Natie's Avatar
C5Natie
Dont forget the L99 in Camaros. My 6.2L started life in an Escalade. Its pretty easy to delete the vvt/dod system.
Old Dec 17, 2012 | 01:26 PM
safariowner
Cruising
i dont need to delete it jus was curious if the vette 6.2 had it or not it does not and thats fine i building for hp, im goin to stroke it and use underdrive pullies and couple of bolt on mods and shorty headers straight to side pipes
Old Dec 17, 2012 | 01:57 PM
C5Natie's Avatar
C5Natie
Im guessing you have a 6.2L already? If so, yeah these motors make plenty of power with simple mods. Mine makes 470rwhp with just a cam, 10% ud pulley and 1 3/4 headers. Thats a stock block too. Sounds like youre gonna have a solid setup. Good luck with the build.
Old Dec 17, 2012 | 06:21 PM
_zebra's Avatar
_zebra
good luck with side pipes. do you have a wide body kit that extends the rocker panels out or something? that's what it takes to do them on a C5 or C6
and don't forget that the DoD/VVT stuff is more than a tune - it uses different lifters and cam gearing as well a some other pieces that are physically different that their LS3 counterparts
Old Dec 18, 2012 | 07:55 AM
AU N EGL's Avatar
AU N EGL
mpg Cut off? No.
your computer programing has more to MPG
to increase HP might want to looking at better heads vs the LS3 heads, different cam per required use, intake and LONG tube headers. Shorties do nothing or very little.
there are quite a few LS3 or 6.2l blocks stroked to a 427 ( 7.0L ) so that is not an issue.
Old Dec 18, 2012 | 09:08 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Well, not really they don't. Not in a production car anyway. Even the 7.0 is a small block, fyi.
To 6.2l questions
