Tdr
Old Dec 19, 2012 | 11:35 AM
mmartinez's Avatar
mmartinez
Default Tdr
I am helping a fellow corvette owner troubleshoot his intermittent no cranking problem. I will be using a DMM on the TDR relay to determine if the +12V is present from the switch and if -12V is present from the BCM. How do you determine if the BCM is the problem or if the the problem is with the key switch contacts which reads the resistance of the key or wiring going to the BCM?
