Horn doesnt work with alarm
Old Dec 19, 2012 | 03:44 PM
CLEAR's Avatar
CLEAR
Default Horn doesnt work with alarm
My horn stopped honking when I use the keyfob to lock the doors suddenly. I messed with the settings in the DIC and it worked once when I locked the doors but still not working.
Old Dec 19, 2012 | 06:10 PM
50thZ's Avatar
50thZ
Mine does not work either? I checked fuses etc, but nothing? Lights flash?
Old Dec 19, 2012 | 07:53 PM
kenzo's Avatar
kenzo
Did you check the horn relay?
Old Dec 19, 2012 | 09:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your horn works with the steering wheel, the fuses and relay is good. I would look in the DIC settings and recheck the settings.
BC
Old Dec 19, 2012 | 09:20 PM
CLEAR's Avatar
CLEAR
BC
done all that a few times
Old Dec 19, 2012 | 09:37 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Look on the BCM and find BCM connector C1. Disconnect the connector and in that connector, ground pin B10 (black wire) If the horn BEEPS, the BCM driver in the BCM for that function is bad or the BCM circuit board has a bad solder joint.
BC
To Horn doesnt work with alarm
