intermittent vibrations 55+ mph
Old Dec 20, 2012 | 12:26 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
Default intermittent vibrations 55+ mph
I own a 1999 Corvette C5 with 29,000 miles on it.
I'm having a vibration-two second gap-vibration in the 55-65 mph range felt through the gas pedal, seats, and just about all around except the steering wheel.
it is more apparent through the steering wheel at higher speeds such as 70+
on hard banking turns on left front side a small bump is at a specific point when the tire rotates like clockwork
-tires with 2,000 miles on them,
-rims are not bent (already checked)
car was lifted to see if any of the suspensions rubber is rotted.
only thing that could use a replacement rubber wise is swaybar bushings and end links which i dont see why would be the cause of this
tires were balanced on a Roadforce machine
My guess is the wheel bearings are just dried out from the car not getting more then 2,000 miles a year but im not an expert.
Any help is greatly appreciated thank you
Old Dec 20, 2012 | 01:26 PM
thmehr's Avatar
thmehr
I am thinking well bearing too. Jack the front end up, and grap the tire at the 12 and 6 o'clock positions and see if you can find some play. Do this again at the 3 and 9 o'clock positions. If you find any play, time for new bearing. Not hard to do. If you are racing or just playing hard, get one of the racing bearings, cost over $300. If you just drive the car, you can get a GM bearing, which I would not do since they seem to have an issue with them, or get a timken(sp?) bearing. Cost around $125.
Old Dec 20, 2012 | 02:08 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
Tried it, no play and when the wheel was spun while jacked there is no grinding....granted things can be different when the tire is under weight, i might just be catching the issue extremely early or its something else but its the only thing that makes sense
Old Dec 21, 2012 | 12:52 PM
_r2h's Avatar
_r2h
You can still have a bad bearing even though you have no play in it.
Old Dec 21, 2012 | 03:00 PM
onlyavette's Avatar
onlyavette
How old in years are the tires? Lift the tire off the ground and spin it. Look for high spots on the tread area and side wall. I have had tires separate that had less than 10k mi. on them.
Old Dec 21, 2012 | 03:25 PM
slimsol's Avatar
slimsol
do you have stock rims or aftermarket ones?
Old Dec 21, 2012 | 09:09 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
tires are 1 month old and 2,000 miles on them....tread seperation wasn't visable
I have the stock ones
Old Dec 22, 2012 | 05:43 PM
Lloyd Christmas's Avatar
Lloyd Christmas
Is the vibration still present at the same speeds if you push the clutch in?
Old Dec 22, 2012 | 06:03 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
Yes, it seems to only come from the front left tire....on hard banks to the left when weight is taken off the front left tire the vibration becomes less noticed
Old Dec 23, 2012 | 07:39 PM
Ozzysezit's Avatar
Ozzysezit
Im no expert on Vettes, but I have been a Mechanic all my life. Your issue could be in the shock absorber. If the wheel/tire is balanced and the bearings are ok its very possible that you have a "flat" shock absorber.
A harmonic imbalance from a flat or dead shock absorber could cause these conditions.
Just an idea to look at.
Old Jan 10, 2013 | 01:15 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
I've decided to take it to corvette world in Carrollton. balance, alignment, and bearings later i am lost.
The person who accepted my car says it can still be the wheels/rims even though they have only 2,000 miles on them. hopefully this repair doesn't cost much more
Old Jan 14, 2013 | 04:42 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
By any chance could this be a torque tube bushing issue?
Old Jan 14, 2013 | 05:04 PM
thmehr's Avatar
thmehr
One last thought, have the tire rebalanced. It should still be under warranty for the balance. I always get the life time balance when I do my tires.
Old Jan 14, 2013 | 05:31 PM
wcsinx's Avatar
wcsinx
These newer bearings have to practically fall apart before they exhibit any noticeable play. I just replaced one in my wife's Grand Prix. The thing was howling so loud you couldn't hold a conversation in the car anymore. There was 0 zero play in the wheel no matter how I pushed or pulled on it, but when I pulled the bearing and rotated it by hand *crunch* *crunch* *crunch* it went.
Old Jan 14, 2013 | 05:47 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
I have had three separate companies balance the tires so far.....Discount tires, Corvette world, and even a NTB....every time i got it back i still had a vibration :-(
Old Jan 14, 2013 | 05:50 PM
ThunderZTA's Avatar
ThunderZTA
8th Gear
i dont have any noise coming from mine currently. can they still be bad with no noises or play???
I'm starting to think from what I've read is it can be the Torque Tube Bushings and am hoping someone can maybe shed some light on this.
The car has sat alot of its life and the rubber could be dried out?!?
To intermittent vibrations 55+ mph
