Running the vette without catback exhaust??
Old Dec 21, 2012 | 01:11 PM
mig1980's Avatar
mig1980
Default Running the vette without catback exhaust??
Good day everyone. I am in the process of swapping exhaust from b&b bullets to stock z06 Ti exhaust (for personal reasons).
The issue is that I won't be able to coordinate the swap at the same time. Would I be OK removing the b&b at my house and driving the car without catback exhaust in a few weeks to a shop to install the Tis?
Old Dec 21, 2012 | 01:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well, heres my opinion...... It will be VERY LOUD and you will expierence EXTREME Interior Cabin Resonance. The resonance will be the KILLER paryt of the expierment. Been there,, done that.
You will have an Indy car expierence! However,, Look where the open mid pipe will exhaust to..
Right on the "K" member/REAR SPRING area.. If you can protect the spring, then you should be good for a short drive.
Did I say that you will have MASSIVE DRONE???
BC
Old Dec 21, 2012 | 02:09 PM
Chris Stewart's Avatar
Chris Stewart
it will be ridiculous BTW that is a clean vette Bill!
Not exactly what you had in mind, but here's what I did once:
Old Dec 21, 2012 | 02:29 PM
mig1980's Avatar
mig1980
You mention protecting the rear spring. How would I do that without spending money buying pieces to deviate the exhaust from the mid pipe?
Old Dec 21, 2012 | 05:13 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, Other than installing turndowns it all depends on how far you have to drive and how long you plan on leaving it that way.
If its just a short hop to a garage, find some heavy duty aluminum foil and wrap the spring with foil and use the foil to direct the gasses around the K member...
Chris Stewart
That was WAAAAAAY back in 04. Its NOWHERE that clean now!!
Bill
BC
Old Dec 21, 2012 | 06:27 PM
YELLO C5's Avatar
YELLO C5
Do you have AAA? I have the Plus RV which includes 3 free tows up to 100 miles. I've used it to move cars.
Old Dec 22, 2012 | 02:47 PM
mig1980's Avatar
mig1980
Gosh, if thats the case, I am going to just wait until and can do the swap at a shop. If the deal falls through, oh well. Thanks guys for the info.
Old Dec 22, 2012 | 10:37 PM
billvh's Avatar
billvh
If you're going to remove the B&B's, you could install the Ti's too, just need to get it high enough in the air to get the pipes over axle.
Old Dec 23, 2012 | 11:32 AM
NukeC5's Avatar
NukeC5
I drove around without an axle back for a week to see if I'd like the sound of straight pipes. Didn't hurt anything or discolor anything etc. It wont be an issue, just annoying.
To Running the vette without catback exhaust??
