How to remove evap solenoid
I'm starting to tear the car apart for my H/C/I install. I've had good luck so far but last night got stuck with removing the fuel evap solenoid connection from the intake manifold. I'm following ls1howto.com it says just compress the white clips and it easily slides off. I'm using a set of hose clamp pliers and trying to grab and compress the white clip on either side and slide it off, just isn't working. Any suggestions?
