This is unrelated to a C5 or LS1 for that matter. But the idea here should be the same.
I have been working with a coworker trying to fix a misfire on her car. My scanner reads cylinder 5 misfire. So far I have changed the spark plugs, wires, and injector for that cylinder. I have verified that the coils are good with an ohm test, and that the injector has power (same readings as all the other injector wires). I have done a compression test and the cylinder is at 140psi and holds there fine.
The funny thing is that when I unplug the injector while the engine is running, I do not get a change in the way the engine runs like I do when any other cylinder is unplugged. (Hence why I changed the injector in the first place). This is the same even with the new injector.
Its a 1999 Grand Prix 6 cyl. Car is totally stock.
Basically Im wondering what I am missing here for tests.. any ideas? I watched the gauge on the compression tester climb three or four times which showed me the valve is opening and closing. I have verified fuel, spark, air, compression, and no vacuum leaks. So what else can I do before I take the valve cover off and start checking the valve train more in depth?
GM injectors fire when GROUNDED by the ECU. That injector could have a bad ground. You can use a noid light to test if it's firing or use a pencil or screwdriver to listen for the ticking of the injector when the engine is running.
Carefully examine the connector for the coil and injector. Make sure that the female pins are not deformed and make good contact with the male pin on the component.
Check the wires for the correct power, ground and signals to make the components work.
Bill
Great suggestions guys I will double check all connections. I will try a noid light and see if I get anything. Never tried that before. Makes sense.
You really need to break out the Digital Volt / Ohm meter and a magnifying glass for the best chance of solving the issue!!!
I do have a digital meter and tested with it, I am no expert, but I tested both prongs in the injector connector and verified that they are the same readings as all the other injector connectors. To me that says they are fine... but like I said, I feel like Im missing something here.
Perhaps he is saying to swap the components from a known, properly-firing cylinder to the suspect cylinder, one component at a time. Slightly different from a wholesale changeout of parts. Also, if you change ALL of the parts at once, how would you know which component solved the problem?
I think Bill is right. You're gonna need to troubleshoot this thing a little more. If you changed the injector, the plug, and the coil pack, it suggests to me that the problem is most likely in the wiring, as Bill so aptly suggested. If it hasn't already been suggested, I would also check the wiring and connectors of the PCM/ECU side of the harness, and the ground for that cylinder's injector. Just my $0.02
On a side note, it is somewhat annoying when people only chime in with their smart-a$$ remarks rather than making a positive contribution to the thread.
I'm the one that told him to check the ground at the top of this thread. Can you read??
