the issue is misfire/misfires i checked the wires abd there was one that was real bad so i replaced all of the wires. and i changed the plugs while i was at it. i had purchased a cam and had a installer/tuner install and tune it . he said the engine was not receiving enough fuel . it would bog before at lower rpm when leaving stop signs / street lights . it still doesnt feel right buuuut there is no check engine light anymore a local mechanic heard it i was leaving a Buddies shop and with knowing nothing about my car he said it has a misfire . i suspected it was still there is there any way of checking . i have no check engine light or codes and am pretty frustrated at this point please help any suggestions. ps getting rid of AutoZone wires soon
If your car was running fine prior to you taking it to a shop to have the cam installed/tuned & then after the cam install you have signs of a miss & fuel starvation.... Take it back to the shop that did the cam/tune & have them make it run right.
Lack of fuel after a cam - assuming the stock fuel pump or injectors are in play - will NOT make it bog off idle. It will show up at higher RPM when the fuel demand increases.
it was not runing fine before cam . and was installed by a friend that has done several without any issues im going to take her out for a spin and hopefully the engine light comes on its honestly whenever it feels like it could it be a coil?
