11:1 Compression What Fuel?
Old Dec 31, 2012 | 08:34 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default 11:1 Compression What Fuel?
What fuel would you need for an 11:1 compression crate EFI motor?
Old Dec 31, 2012 | 08:47 PM
sunchaser73's Avatar
sunchaser73
I have the same CR...I run 93 with no issues. Just make sure you get a reasonably conservative tune.
For CT area tuners, I would recommend Mike Levesque, owner of J&M Motorsports. He's located on Broad Street in Manchester.
Old Dec 31, 2012 | 08:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
$$$$$EXPENSIVE FUEL$$$$$
I would say at a minimum in the summer, 93 Octane. In the winter, you could get away with mid premium.
To insure that you know the real answer, your are going to have to data log and see if you have any incurable KR under heavy loads and WOT.
If you run 92 Octane, Consider Meth Injection to keep the KR in-check. With the right tuning, you should be good to go. Who will be tuning the engine??
Bill
In Gales Ferry CT
Old Dec 31, 2012 | 08:53 PM
sunchaser73
Very true, Bill...especially up your way. I remember the high gas prices quite well. Much cheaper down here in SC....
Old Dec 31, 2012 | 09:05 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I actually used J&M Motorsports for my first tune on my 02 ZO6.
Stainless Works headers and a vararam. Made 385 RWHP 375 Tq
I now use Corvettes of Westchester Chuck does a fantastic job.
Old Dec 31, 2012 | 10:14 PM
BPHORSEGUY's Avatar
BPHORSEGUY
The engine comes with a ECM tuned by the builder but I will keep your recommendations in mind for a double check!
Old Dec 31, 2012 | 10:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Keep in mind that your going to have a very modded C5 and LS engine. The tune that they provide is basically a mail order tune. With 11:1 compression,, it will be to your advantage to complete your engine and mod install and then have the engine tuned in the most severe driving conditions that you will subject the car to (ie 90 degree 90% humidity track day at Epping NH!)
The tune that they give you is a very good starting point!
Bill
Old Dec 31, 2012 | 11:02 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Bill
In other words bring it to J&M or Westchester to make sure its tuned properly in my final configuration! Anybody have experience w/ Corvette Center in Newington?
Old Dec 31, 2012 | 11:12 PM
C5Ryan's Avatar
C5Ryan
my compress comes in right under 11.5:1 and I run 93 on motor, 100 on nitrous. this is on a forged bottom end.
Old Dec 31, 2012 | 11:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXACTLY! Pick the tuner that you desire but,, get the car retuned ON THE STREET, so that it is tuned to real time conditions!
I have an excellent relation with Chuck at Corvettes of Westchester and he does an excellent job. If I think that theres an issue with the tune,, he rechecks it without question.
One of the best customer based Tuners that Ive found so far!
The main goal is to get a finial build tune!
Old Jan 1, 2013 | 10:05 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
If you want it tuned correctly www.slowhawkperformance.com
step over to the ls1tech site for some background on the above tuners, you'll get a good idea in what area each one does well in.
Use the C5 F/I section and see how the results are for another comparison.
Are you asking what fuel the stock GM C5 Z06 uses? stock LS6 compression is 10.9:1
Pump gas, Premium
Old Jan 1, 2013 | 11:01 AM
NukeC5's Avatar
NukeC5
Here in Cali, 91 octane is the highest at the pump. Guys here build 11:1 engines all the time and do not have trouble. Maybe on the strip in the summer time it would be a good idea to add a booster, but other than that, the engine will do fine. If you live where the fuel is 92 or 93, you are in great shape.
Old Jan 1, 2013 | 06:01 PM
Spreader's Avatar
Spreader
I replied to your other thread about the swapped FRC. I have 11.7:1 and I'm running 91 octane. AFRs are at 13.3 with no knock, a bit lean, but my tuner is comfortable with what he saw through the tuning process.
Old Jan 1, 2013 | 06:17 PM
BPHORSEGUY's Avatar
BPHORSEGUY
So it looks like 93 which is available in my area will work fine!
Old Jan 3, 2013 | 09:20 AM
blackdak318's Avatar
blackdak318
I'm very surprised no one has commented on the difference between static and dynamic compression and which one really effects the fuel you can use. To the OP do a little research on them both and educate yourself first.
Old Jan 3, 2013 | 10:06 AM
sunchaser73
Not sure how many people actually know about SCR and DCR. I know I didn't!
I ran a quick search and found this: http://www.empirenet.com/pkelley2/DynamicCR.html
I scanned through it...gonna have to go back and thoroughly read it. It has download links for a Visual Basic program to do the DCR calculations. I'm going to try it out later and see what I come up with.
Thanks for giving me something to do on a rainy day!!
Old Jan 3, 2013 | 12:59 PM
blackdak318
That is a VERY good article. I'm not super knowledgable by any means but I was lucky enough to run across a good thread about this on LS1 tech. Just do a quick google search of dynamic compression pump gas ls1 and there is some decent reading.
To 11:1 Compression What Fuel?
