It finally begins............
Old Mar 12, 2013 | 10:48 AM
Dnealy's Avatar
Dnealy
You possibly wanna trade that intake, lol. Looks awesome. I have a ported fast that would be just perfect for your NA build haha. (you know the sales technique, i need to make you realize why you need/want what i have hahaha). Shoot me a PM.
Old Mar 19, 2013 | 09:45 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Hahaha, I haven't gotten that far yet............have you priced a custom aluminum intake?
Old May 19, 2013 | 09:24 AM
Cruise-In V Veteran
NCM Ambassador
Not much left before I yank it:
Poor PCV set up they had shows on the rockers.....
One head stud............interesting build
A little mis-alignment on the #6 exhaust push rod.....
Old Aug 18, 2013 | 09:06 PM
Cruise-In V Veteran
NCM Ambassador
Some more done...........time to yank it next!
Old tools come in handy
I used this old "S" wrench to break free the bolt it is on...........couldn't get anything else on it with the stuff in the way. I wanted to leave the tunnel plate on to hold up the torque tub & rear once I pull the motor
If you haven't see the clutch fluid coupler apart.....
Old Aug 25, 2013 | 07:22 PM
Cruise-In V Veteran
NCM Ambassador
I got a great deal on this Friday on the way home from work from harbor Freight........$16.95 out the door!
The biggest thing for one person, is this tool and to have the torque tube jacked up to allow the engine to be above the front cradle allowing you to easily twist it out. Ileft the tunnel plate in to support the to tube, plenty strong for the job.
My 3 ton chain fall with chain bag(stylish eh?) was great!
This is how much the lower cradle has to be dropped to clear the oil pan/steering
Here is where the 2 x 4 & jack go on the tube:
Just about out!
OUT!!!
Clutch dust!
And my tire dolly does fine to push it around till I get it on the engine stand, thats next!
Old Nov 3, 2013 | 09:27 PM
Cruise-In V Veteran
NCM Ambassador
Update....................see if you can tell what may be the problem from the oil pan..
Old Nov 4, 2013 | 02:47 AM
_r2h's Avatar
_r2h
That oil pan
Old Nov 4, 2013 | 04:07 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by _r2h
That oil pan
Bearing fragments??
High dollar rods.
Old Nov 4, 2013 | 06:08 PM
Cruise-In V Veteran
NCM Ambassador
Hoping for the best on the journal..................expecting the worse though...it's got a 1/16" slop
The heat blued rod cap & 1 rod bolt tell a tail...
I will post up the gorry pics of what I find...........
Old Nov 4, 2013 | 06:14 PM
m6 c5's Avatar
m6 c5
Do you think your crank might still be ok even with the discoloration?
Oh and how hard was it to get the motor out with the rack still in place, I think mine is going to come out in a few weeks.
Old Nov 4, 2013 | 08:41 PM
Cruise-In V Veteran
NCM Ambassador
Don't Know yet............I am not holding my breath
As long as you have a load leveler, it will come out no problemo
Old Nov 4, 2013 | 09:12 PM
m6 c5's Avatar
m6 c5
Yea I have a leveler but ill be using an engine crane not a beam but I guess it should be the same. I've got a few parts that ill be installing during Christmas shutdown at work and I'm trying to figure out if it would just be easier to pull the motor.
Old Nov 13, 2013 | 08:00 AM
  #33
Cruise-In V Veteran
NCM Ambassador
And the problem...........
Of course the crank hitting the piston skirts didn't help......
Pistons don't look good either..........no wonder it burned oil!
Looks to me like original start up oil starvation..............no priming!
Old Nov 14, 2013 | 04:58 PM
  #34
m6 c5's Avatar
m6 c5
Yea that doesnt look too good...
Do you have any tips on pulling the motor? And how did you break the crank bolt lose?
Old Nov 14, 2013 | 05:43 PM
  #35
RedZMonte's Avatar
RedZMonte
One Head stud? im thinking 1 Head locating pin! Lol
Intersting intake manifold. definatly see it not helping TQ. need runners 2x longer in a X configuration and a larger volume Plennum to make something like that work well
looks like its chewed up pretty good. Crank shop can tell if its fixable, alot of the time the bearing material looks all jacked up but once its cleaned/micro pollished its good and the machine shop can match up your pistons/crank with the right size bearings. Pistons are junk.
Old Dec 5, 2013 | 03:08 PM
  #36
Z06ufgrad2002's Avatar
Z06ufgrad2002
Man that's some nasty damage. Considerably worse than my current situation which is also requiring a completely new bottom end.
Do you know who assembled the rotating assembly?
Old Dec 5, 2013 | 10:49 PM
  #37
Cruise-In V Veteran
NCM Ambassador
Real Performance Motor Sport Lewisville, TX
I still have to finish dis-assembly to see all the damage
Time will tell
Old Dec 6, 2013 | 10:42 AM
  #38
Z06ufgrad2002
