question replacing brake booster
Old Jan 3, 2013 | 11:06 AM
c6miller's Avatar
c6miller
Default question replacing brake booster
Have a 2003 with 25,000 miles. The brake pedal rod is making a rubbing noise at the firewall where it goes to the booster. Dealer is replacing the booster(too big a job for me). The vacuum line is OK but I thought that I'd replace it due to age, the shop manual says you need to remove the intake manifold to replace the hose. If that's true I'll leave it alone but does anyone have a shortcut to this. Thanks
Old Jan 3, 2013 | 05:59 PM
dannyman's Avatar
dannyman
Really? Need to make sure that line is a problem first!
Dan
