C5 Intake Housing
Old Jan 7, 2013 | 11:07 PM
P38rider's Avatar
P38rider
Cruising
Default C5 Intake Housing
Anyone know if a C5 Z06 air filter housing will fit a standard 2003 C5?
Old Jan 8, 2013 | 11:02 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The only difference between all the housings are the covers and YES they will fit just fine.
IF,,,,,,,,,,, you take yours apart.. Its a LOT easier to remove the complete assembly. It is attached to the front cross frame with two metal pins mounted in a rubber washer/gromet/ It just pops off!
While itsout, clean the MAF with maf cleaner and perform this mod on the retainer straps.
Make sure that you reconnect the ducting back correctly and have an air tight seal on everything between the TB and MAF.
BC
Old Jan 8, 2013 | 11:23 AM
P38rider's Avatar
P38rider
Cruising
Thanks for your quick response.
To C5 Intake Housing
