switchback led hyperflash-inline resistor install?
Old Jan 8, 2013 | 06:34 PM
andy9743's Avatar
andy9743
Default switchback led hyperflash-inline resistor install?
picked up a set or switchbacks and inline resistors to correct hyperflash...i know the module is easier but they are sold out and i want to get the front of my car back together. what of the three wires going to the bulb do i tap with the inline resistor?
thanks
Old Jan 8, 2013 | 07:59 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
1 end to the blue/white wire and the other end to the black wire.
Old Jan 8, 2013 | 11:11 PM
lionelhutz's Avatar
lionelhutz
Just get a flasher and do the flasher bypass yourself. Will cost you <$10 and will work way better than adding resistors which I read about failing all the time. Besides, hacking into your exterior wiring isn't a good idea if the car ever sees water since you're opening the wiring up to corrossion issues. Info and pictures are is in the FAQ/DIY sticky thread.
To switchback led hyperflash-inline resistor install?
