On the way home tonight,My c5 just started running rough,idle was fair but acceleration real rough. No codes in Dic either,kind of strange..any ideas? It almost seems that if I really laid into the pedal it would clear itself and run fine but then come back rough again. I did notice at idle and hour later it would fluctuate from a good idle then back to a little rough and back again to smooth,any ideas?
I did have the plugs and wires off earlier in the week to drop headers as well as change out coolant temp. sensor....
I have no specific insight to your problem... but....
I'm no mechanic, but I have been wrenching on my cars since the early 70's. I have found that if a problem pops up after I have done some kind of work on the car, 99% of the time, the issue is with, or around, whatever I just worked on.
Barring someone chiming in with a specific possible fix... I'd recheck the wires, plugs, coolant temp sensor, and anything that could have been disturbed when you dropped the headers...
