2002 Z06 with whining noise problem need help
Old Jan 14, 2013 | 11:54 AM
Racinjace22's Avatar
Racinjace22
Default 2002 Z06 with whining noise problem need help
I just got a bad whining noise some gears are louder than others. Only under load. When I push the clutch in sound goes away. And when I left off the throttle the sound weakens. It's sounds like a gear whine. I was thinking it was the torque tube or trans. But after doin research sounds like the rear end is in trouble. Anybody know? I could take it for a ride and shoot a video and send it to you. And opinions will help thanks!
Old Jan 14, 2013 | 10:36 PM
corvette77's Avatar
corvette77
When was the last time the trans and rear end fluids were changed?
Old Jan 14, 2013 | 10:42 PM
Racinjace22
Every 3000 miles the car only has 21k miles
Old Jan 15, 2013 | 01:02 PM
donnie brooks's Avatar
donnie brooks
Default gear whine
M 99 6 speed makes the same noise,when I push in the clutch the noise stops,I leave it in gear when I push in clutch,this tells me that the whine is not from the tranny or gears or the torque tube since the gears are still turning when coasting in gear.
Please let me know what you find out.
Old Jan 15, 2013 | 01:04 PM
Racinjace22
Will do man. I was thinking the same way. I have a video of it if you want me to send it to you and see if it sounds the same way
Old Jan 15, 2013 | 04:46 PM
Alvin@PCMofNC's Avatar
Alvin@PCMofNC
Supporting Vendor
Is it worse if your lightly resting against the shifter?
Old Jan 15, 2013 | 10:33 PM
rodsvet's Avatar
rodsvet
You changed your trans and rear end fluid every 3k? Did you use the friction modifyer in the diff? You never need to change the fluids that often unless those were extremely hard constant track miles, and still that is way too often.
Old Jan 15, 2013 | 10:43 PM
Racinjace22
Change my engine oils every 3k back fluids 5k I run the car hard, and yes the friction modifier is in the diff. It's the pinion gear in the diff musta broke a bearing and put the shaft out of a lineament creating the gear whine.
To 2002 Z06 with whining noise problem need help
