LS6 valley cover
Old Jan 15, 2013 | 10:49 PM
NukeC5's Avatar
NukeC5
Default LS6 valley cover
I am trying to pick the right one of these valley covers. Anyone one know which part number is for which engine, and which is the best to use on the LS1? Would the latest style have any benefits over the earlier? Or should price be the ruling factor?
The three part numbers I have found are:
12570471
12568002
12577927
Old Jan 16, 2013 | 11:07 AM
f6john's Avatar
f6john
Old Jan 16, 2013 | 11:47 AM
vettenuts's Avatar
vettenuts
I don't recall the part number and would need to check my photos, but I believe it to be the last on your list. I installed the one that doesn't require an external PCV valve as the restriction is built into the cover itself. If someone doesn't verify the number I can check later.
Old Jan 16, 2013 | 01:42 PM
Cutlassmaster's Avatar
Cutlassmaster
I have a 99 and used 12577927 with a catch can. I had to cut a small chunk out of the block so it would fit. I have almost eliminated oil consumption using it. I found a forum that showed hot to do the conversion and to re-route the hoses. I would suggest using 12577927 if at all possible.
GL
Chris
Old Jan 16, 2013 | 03:19 PM
Lothar34's Avatar
Lothar34
http://www.ls1howto.com/index.php?article=18
12568002, according to this.
Old Jan 16, 2013 | 03:40 PM
Cutlassmaster
I used those instructions but with12577927. I just did this back in April 2012. For that cover and the plug listed on the above site I paid $88.34 shipped from GM Parts House (Patrick).
Old Jan 16, 2013 | 04:08 PM
vettenuts's Avatar
vettenuts
Just checked my photos as well, I used part # 12577927 with catch can. No external in line PCV valve required.
Old Jan 16, 2013 | 08:16 PM
NukeC5's Avatar
NukeC5
Alright great! Thanks guys
To LS6 valley cover
