Difference between 97-00 and 01-04 headers?
Old Jan 16, 2013 | 11:13 PM
Dobbinshabby's Avatar
Dobbinshabby
Default Difference between 97-00 and 01-04 headers?
I just bought some 01-04 long tube headers for my 99, did I dun goof?
What are the differences, I made the assumption they would fit...
Old Jan 16, 2013 | 11:52 PM
mynameisray's Avatar
mynameisray
Ive wondered that myself. Found a good deal on some 02's but wasn't sure if theyd fit my 99 FRC
Old Jan 16, 2013 | 11:58 PM
RonSSNova's Avatar
RonSSNova
Only difference is the air tube connections.
Ron
Old Jan 17, 2013 | 12:41 AM
Dobbinshabby
Ron
Oh that is relieving thank you. Now this may be a long shot, but the person I bought the headers from welded the air tube connections closed (unrepairable), is junking that whole air system easy to do?
Old Jan 17, 2013 | 02:00 AM
RonSSNova's Avatar
RonSSNova
Yes. Just remove all of the hoses etc and have someone with HPT or EFI live tune out the AIR portions of the diagnostic trouble codes.
Ron
Old Jan 17, 2013 | 04:38 AM
vettenuts's Avatar
vettenuts
And suddenly spark plugs are easy to get at
Old Jan 17, 2013 | 06:46 AM
1999_TRC's Avatar
1999_TRC
Ron
Nothing different with the dipstick?
Old Jan 17, 2013 | 10:22 AM
NukeC5's Avatar
NukeC5
Air tubes are the biggest concern. Those seeking shorties would find differences in the air tubes and mid pipe connections. Long tubes are just different at the air tubes. Be sure you do not have to pass emissions before deleting your air injection system
Old Jan 17, 2013 | 10:30 AM
Cutlassmaster's Avatar
Cutlassmaster
I installed my XSPower headers about a year ago. I also have a 99 and you will have to modify it to bolt up a different way or replace with an 01 - 04 model dipstick. I cut the flat bracket, bent it a little, drilled the hole to bolt to the air tube bolt on the header. 8K miles later still no issues. Hope that answers your question.
Chris
Old Jan 17, 2013 | 01:04 PM
lionelhutz's Avatar
lionelhutz
Yes there is. 97-00 bolts to the manifold and 01-04 bolts to the block. Either replace with newer or modify to work. I modified and bolted mine to the air tube flange since the air tube isn't installed.
To Difference between 97-00 and 01-04 headers?
