Third brake light
Old Jan 19, 2013 | 07:26 PM
Evil Oil Apologist's Avatar
Evil Oil Apologist
Default Third brake light
Can't get it to light up. So the solution trail might be......
1. Check a fuse. Which one under the passenger door controls it? Also, my hood light is out
2. Pull light bar and check it?
3. If I strike out at the above, could I tap the third brake lights positive and negative wire into a regular brake light circuit?
Am I missing something stupid because I'm stupid?
Old Jan 19, 2013 | 09:23 PM
Vic'sVette's Avatar
Vic'sVette
I've heard that the connector sometimes comes loose. Remove license plate and license plate cover and you can reach up thru there and access the connector that way to see if this will work. Good luck.
Old Jan 22, 2013 | 04:23 PM
Evil Oil Apologist
Originally Posted by 8VETTE7
If your other brake lights are working, it is not a fuse. There is no separate fuse just for the 3rd brake light.
What is the "light bar" that you are referring to??? If it's the 3rd brake light itself, yes, you can take it out and use a battery to check the bulb. There are two small screws that hold the light assembly in place. I think they were 8mm hex. When you get it out check the two pins that the wiring harness plugs into. One pin was bent on mine causing it not to illuminate. Access is from behind the license plate as already mentioned.
Yes, other brake lights are working. I've replaced the 3rd brake light bar once before. I'll test the bar with my multimeter or just a simple battery test.
The information about the 3rd being on the same circuit (same fuse) helped a ton. Thanks. Just narrows down the detective work. Kudos!
Old Jan 23, 2013 | 12:22 PM
Evil Oil Apologist
Light bar tested. Works just fine.
Cleaned up connectors (male and female).......no joy.
Traced wires back to bundling, but really don't care to open that up. Back to the original bailing wire option of running third brake wires to brake lights hot and ground wires.
Any other ideas? Thanks a ton guys!
To Third brake light
