Swapping C5 shifter for C6
Jan 22, 2013 | 05:51 PM
Had a few questions on doing this.
1. Will the C6 shifter bolt right up?
2. Will the C6 shift boot also fit a C5 without modifying it?
3. Also, since I would be using a stock C6 shift ****, where can I get a small corvette jake decal to stick on the shift **** plate? I'd clear coat over it also (or paint over the decal and pull the decal off).
Thanks.
Jan 22, 2013 | 06:17 PM
Try search, done many times.
Jan 23, 2013 | 12:35 PM
I don't have a message from you.
Jan 23, 2013 | 12:50 PM
Sorry yes I am sure, did you erase it from your sent folder?
Jan 23, 2013 | 01:19 PM
I tried searching but could not find out if people have used the C6 shift boot on a C5.
Jan 23, 2013 | 07:02 PM
Thanks for the help Bob
Jan 23, 2013 | 07:35 PM
Jan 24, 2013 | 07:24 AM
Does the C6 shifter have a shorter throw than the C5?
Jan 24, 2013 | 09:30 AM
Quote:
Originally Posted by
jlaw1313@comcast.net
Here is a good read & visual in this regards.
http://forums.corvetteforum.com/c5-t...5-non-z06.html
Jan 24, 2013 | 09:40 PM
