Recommendations on a Tuner/Programmer
Old Jan 22, 2013 | 09:46 PM
killerslp's Avatar
killerslp
Default Recommendations on a Tuner/Programmer
I currently have a vararam intake and XS Power longtubes with no cats on a 02 z06. I have done a few searches for inexpensive tuners like diablo sport intune and that looked like the best option. Basically I want to be able to turn off the rear O2's and possibly a predone tune based on the common mods I have. I am not looking for precision tune currently so I would rather not spend the money on a dyno tune yet.
I appreciate any replies.
Old Jan 22, 2013 | 11:56 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
my recommendation is get a mail order tune if you want something cheap. I think there are vendors that will sell you a good tune for @ $150
on the other end, get a dyno tune or buy a wideband and software like HPTuners and do it yourself.
here is the link http://forums.corvetteforum.com/1570313133-post1.html
Old Jan 23, 2013 | 12:59 AM
C5Natie's Avatar
C5Natie
I believe there are sims you can connect to the o2's to fool the ecu into thinking theyre working. If you dont want to spend money on a full dyno tune then talk to a company like Diablosport. They can sell you a programmer with a custom tune in it. Theres a list of forum vendors that are tuners that can help as well. Just know that a mail in tune usually involves you removing the ecu and sending it in so the car will be down for that period.
Old Jan 23, 2013 | 04:43 AM
vettenuts's Avatar
vettenuts
Many tuners will charge a larger amount up front and then later tunes as you add parts are less expensive. I have also found over time as the software improves and the tuner gains more knowledge they can tweak other portions of the tune with each visit.
Old Jan 23, 2013 | 10:28 AM
Blitzkrieg's Avatar
Blitzkrieg
AKA "The CLOWN"
This will be about the best route you can go for the price. Doug did a mail order tune for me about 5 years ago, perfect, and quick turn around!
You WILL be pleased with the results, send him a PM!
http://forums.corvetteforum.com/c5-s...nly-149-a.html
Old Jan 25, 2013 | 01:39 PM
killerslp's Avatar
killerslp
thanks blitz, that is looking like my best option currently since even if I get one of the tuners I would still need to spend $150 on a custom tune to disable the rear o2's. Basically my current concern is I have to pass an electronic emissions test in may and from what I have read if the rear o2's are disabled it should pass the check.
I did find these http://www.bigdaddiesgarage.com/straight-cel-fix.html
but not sure if they would work right or not. the mini cat one they have should definitely work but at $50 each I would be better of paying for the tune.
To Recommendations on a Tuner/Programmer
