Emergency Brake Adjustment ???
Old Jun 13, 2002 | 09:37 AM
jroman's Avatar
jroman
Default Emergency Brake Adjustment ???
Losing brake holding. Is there an adjustment to 'tighten' the emergency brake. '99 vert. Please help and thanks in advance.
Old Jun 13, 2002 | 12:44 PM
mozin's Avatar
mozin
Default Re: Emergency Brake Adjustment ??? (jroman)
Try yanking on the brake handle repeatedly to force the automatic adjuster to work.
If this does not work there is a procedure where the wheel comes off and somehow the adjustment is made at the brake itself. Someone will pipe in with this info.
Old Jun 13, 2002 | 01:08 PM
Miles in Michigan's Avatar
Miles in Michigan
You can also try yanking up on the e brake while rolling backward. It's had some success on my car. Do it 3-4 times in a row, see if it helps.
Old Jun 13, 2002 | 01:09 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
My emergency brake will only hold if the car is rolling backwords. :crazy:
Anyone know how to fix that, too?
Old Jun 13, 2002 | 01:26 PM
Traffic Hater's Avatar
Traffic Hater
Default Re: Emergency Brake Adjustment ??? (C5SilverBullet)
The yanking thing worked for me this weekend. I was at cartek this Saturday doing baer brakes and mentioned this to rich the tech. I figured if he is pulling the wheels off anyway, I might as well ask him to adjust my brakes at this time. We'll, he looks at me, looks at the emergency brake lever and starts yanking away. All fixed! Boy did I feel silly! It was that easy. Make sure the push button is not held while pulling up. You should hear the clicking sound. By the way, the brakes look and feel incredable.
Old Jun 13, 2002 | 02:48 PM
mbtc5vette's Avatar
mbtc5vette
Default Re: Emergency Brake Adjustment ??? (Traffic Hater)
My e brake was getting loose too. I corrected the problem by yanking it up when backing up while holding the button in. Tightened right up after 3-4 times. Now I've gotten into the habit of using the e brake to stop when I back out of the driveway every morning and its stays in adjustment.
:cheers:
Old Jun 13, 2002 | 04:12 PM
George Cooper's Avatar
George Cooper
Default Re: Emergency Brake Adjustment ??? (mbtc5vette)
Hold the button in or not? Got two different answers here........
Old Jun 13, 2002 | 04:36 PM
Patches's Avatar
Patches
Default Re: Emergency Brake Adjustment ??? (George Cooper)
DO NOT hold the button down while pulling up. :cheers: :yesnod:
Old Jun 13, 2002 | 07:29 PM
George Cooper
Default Re: Emergency Brake Adjustment ??? (Patches)
Thank you sir!
Old Jun 14, 2002 | 01:21 AM
Duck916's Avatar
Duck916
Yep, as they said, just yank up on the brake while backing. It doesn't matter if you push the button or not--the button just operates the latch in the brake handle itself. The actual adjuster mechanism is in the brake shoe assembly in the rear rotor hat.
Anyone who has worked on drum brakes knows how these adjusters work. The parking brake is almost exactly like an older drum brake.
I keep mine working by cycling it four or five times while backing up once a month. It works perfectly so far.
To Emergency Brake Adjustment ???
