Speedometer reading/calibration
Old Jan 24, 2013 | 05:23 AM
Damillio's Avatar
Damillio
Default Speedometer reading/calibration
Is the speedometer reading based off of rear diameter?
Old Jan 24, 2013 | 09:19 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
good question. I just looked in my HPTuners and it has a place to change this. It also has a place to put in the rear axle ratio. Mine is set to stock (26") so I'm guessing it is the rear tires.
Old Jan 24, 2013 | 09:46 AM
3boystoys's Avatar
3boystoys
NO, i think it drive shaft based BUT, 1 roatation of the driveshaft will move different diameter tires different lenghts-that's why the computer has to KNOW what tire diameter you have so it can do the calculation to display.
Old Jan 24, 2013 | 11:48 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The speed sensor is located in the differential. I copied a couple of pictures from other threads to show them.
The diagram:
Originally Posted by lucky131969
A picture and you can see it at the top:
Originally Posted by Its_Go_Time
Old Jan 24, 2013 | 12:45 PM
lionelhutz's Avatar
lionelhutz
The speed sensor reads from a toothed wheel beside the ring gear. The tire diameter is the only thing that has to be compensated/corrected/calculated to make the speedo read correctly.
Old Jan 24, 2013 | 02:35 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
NO speedo correction when changing axle ratios
Speedo correction IS required for a tire size change
A "shift point correction" IS required on BOTH on an A4
Old Jan 24, 2013 | 07:07 PM
Damillio's Avatar
Damillio
Which tire diameter? Rears only or both?
Old Jan 24, 2013 | 07:12 PM
ZZOOM06's Avatar
ZZOOM06
Rears only.
Old Jan 24, 2013 | 07:51 PM
lionelhutz's Avatar
lionelhutz
The tires connected to the differential.
To Speedometer reading/calibration
