Headlight Malf.
Old Jan 24, 2013 | 06:29 AM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
Default Headlight Malf.
I had Depo flush headlights but went back to stock last night. After installing the lights I tested and the lights went up just fine but only go down when I cycle the switch to off then press the lever foward to the highbeam function. They are not making funny noises or having issues cycling so its not the motor. They were working fine before I took them out. I tried to do a search but didnt find anything so I apologize if this has been coverd before. I checked fuses and all ok. Also dash lights and all other lights work properly including high beams.
Old Jan 24, 2013 | 10:33 AM
Rookieracer's Avatar
Rookieracer
Sounds like you have an HID kit, without a resistor installed. Do a search, lots of info.
Old Jan 24, 2013 | 02:43 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
I will troubleshoot this thanks. I had HID's in my stock lights before though with no issue. I wonder why it would show up now?
Old Jan 25, 2013 | 09:16 AM
99 vett babycar's Avatar
99 vett babycar
previously did you have HID's in both hi and low beams?
Turning the hi beams on to get the lids to go down is SOP with HIDs. I don't mind doing it but if it bugs you then you need to install an inline resistor. I don't like that idea because when you install a resistor it uses energy and disapates heat.I don't like wasted energy or heat.
Old Mar 3, 2013 | 06:35 PM
c5vette211's Avatar
c5vette211
St. Jude Donor '14
So I hate to beat a dead horse but... I have been gone since I posted this and have not installed a resistor. I have used the head lights a few times since I have been home and now a ballast has gone bad. This is the 3rd time in the past year I have replaced a ballast. Is there a fix for this? Will a resistor fix this issue?
To Headlight Malf.
