DRL & Back-up Light Codes
Old Jan 24, 2013 | 10:32 AM
randyfl's Avatar
randyfl
Default DRL & Back-up Light Codes
My DRL's are not working. I recently installed LED Switchbacks and they are working fine (as far as turn signals and parking lights goes). The only issue is no DRL's. I understand they should operate when the headlights are off, engine is running and emergency brake is off.
I am getting a B0502-RH DRL Relay Circuit and B0507-LH DRL Relay Circuit codes. I was getting the codes prior to the LED install. I just hoped they were bad bulbs, no such luck.
I am also getting a B2482-Backup Lamp Relay Circuit code since installing LED back up light. Backup lights are working fine even with the code.
Car is 2002 Z06
Any feed back would be appreciated
Old Jan 24, 2013 | 09:09 PM
randyfl's Avatar
randyfl
Never mind, previous owner remove #2 fuse.
Old Jan 25, 2013 | 03:02 AM
DeeGee's Avatar
DeeGee
That would do it
To DRL & Back-up Light Codes
