Another Gas Gauge Zeroed
Old Jan 28, 2013 | 01:17 AM
Choreo's Avatar
Choreo
Default Another Gas Gauge Zeroed
About 4 years ago I had the usual Gas Gauge dropping to zero and Techron finally would do no more, so GMPP replaced both sensors as my final warranty claim. All was well until a month ago. I ONLY use Chevron with Techron Premium and always add Techron additive each fill up.
About a month ago I was sitting at a red light with about 11 gallons used in the tank and the gauge just dropped to zero and the Low Fuel warning came on. Tonight, got the same thing at a red light and I was right next to a gas station, so I pulled in and filled up - only took 6.5 gallons this time? So am I looking a new sensors AGAIN.
I can't believe that a 3rd party has not come up with a better solution to this chronic problem! I talk to people with other models of cars all the time and they never have this issue?
Old Jan 28, 2013 | 01:43 AM
Choreo's Avatar
Choreo
Originally Posted by 8VETTE7
I haven't followed this gas gauge failure problem as close as perhaps I should, but did the car run out of gas or the gauge just dropped to zero? Did you try using the reset button????
No, the car has never run out of gas... ever. I usually fill up when it gets just below 1/2 tank. Since tonight the car only took 6.5 gallons to fill, there should have still been fuel in both tanks.
I did hit the reset, but that just dismissed the DIC warning - gauge was still at zero and Range was blank.
Old Jan 28, 2013 | 02:39 AM
ZeeOSix's Avatar
ZeeOSix
Have you ever had the ECM reflashed for this issue? There is a TSB from GM that talks about a recalibration flash to help fix the gas gauge going to empty issue.
Old Jan 28, 2013 | 04:15 AM
Choreo's Avatar
Choreo
Yes... unless it lost the flash?
Old Jan 28, 2013 | 10:46 AM
LoneStarFRC's Avatar
LoneStarFRC
I agree with 8VETTE7. Sounds like either R&R your right side sender/pump assembly (the orifice) or replace it John.
Old Jan 28, 2013 | 07:55 PM
Choreo's Avatar
Choreo
Is the "pump" integrated as part of the "sender" unit?
Old Jan 28, 2013 | 08:55 PM
LoneStarFRC
Yes. On the right tank it is. IOW, you can't order just the fuel sender seperately. Same for the siphon-jet section as well.
The left tank is different. There, you can order the fuel level sensor by itself or the entire pump assembly.
The upside, if there is one, is that the right side assembly is much less expensive. Btw, prices have come down quite a bit over the recent years as there is more than one source for this stuff now.
Old Jan 28, 2013 | 11:13 PM
Choreo's Avatar
Choreo
Thanks. I think my Warranty Direct PowerShield Enhanced Extended Warranty covers this fix - guess I will get to see if they try to weasel out of it - never filed a claim on it yet!
Old Jan 29, 2013 | 01:33 AM
Choreo's Avatar
Choreo
Do you know if a Tech II can test for a bad sensor/jet pump with a full tank of gas or do they have to drain the tank first?
I am trying to figure out if I can make a trip to the shop to diagnose in advance so they can order parts under warranty before I have to take it in for the actual repair since I am sure they will not have the parts locally.
Old Jan 29, 2013 | 12:19 PM
LoneStarFRC
The jet siphon pump works on a siphon action created by a small amount of fuel being pumped into the passenger tank by the electric pump in the driver tank. The siphon picks up fuel from the passenger tank and transfers it to the drivers tank. If the jet siphon is working correctly more fuel from the passenger tank makes it's way to the drivers tank than does the pumped fuel from the driver tank so you drain the passenger tank first. No electric or moving parts involved in the jet siphon pump
I seriously doubt there is an easy way to test that action without removing the siphon pump and seeing if the pickup is plugged up by some dirt..... I believe the jet pump can be removed without dropping the tank. If the siphon action fails the drivers tank empties and the passenger tank remains full since the electric pump is feeding the injectors from the drivers tank only.
Exactly........ That's the way it works. As long as he has a non-FFS fuel system car (mid-'03 or '04) this can be done with tank still in car as you say. I also think using Techron at each and every fill-up is massive overkill.
Old Jan 29, 2013 | 03:29 PM
wrmiles's Avatar
wrmiles
My understanding is that this can be tested with a Tech II (or multimeter) by monitoring the fuel sender voltages from each tank and noting whether the left tank stays mostly full (not all the way, I dont know the exact value) while the right tank is at a lower level. I would suggest about half total fuel.
Old Jan 29, 2013 | 03:45 PM
Choreo's Avatar
Choreo
I have a 2001 coupe, but the last time they replaced the sensors in both tanks, they did not have to drop the tanks - just the shields and they removed the sensors from the lower portion of each tank - took about 2 hours.
Old Jan 29, 2013 | 03:50 PM
FASST LN's Avatar
FASST LN
I used to have a problem with the faulty gas gauge as well. It was intermittant. Sometimes I would be 3/4 of a tank and it would drop to 1/4 of a tank. Sometimes it would fix itself. Techron always worked. After a couple of years of this, we moved to another part of the city where I began refueling at a different gas station. Never had the problem again and no need to use Techron.
Try changing gas stations before you go to the trouble of replacing pumps and whatnot.
Old Jan 29, 2013 | 08:59 PM
Choreo's Avatar
Choreo
I admit I am a bit stumped. I understand if the right tank were acting up how I would get the Low Fuel warning at close to 1/2 tank level. But night before last I was only down 6.5 gallons from being topped off when I got the warning? Would that not be a problem in the left tank as well?
Old Jan 29, 2013 | 10:10 PM
C54ever's Avatar
C54ever
Have you seen this thread? It will help a lot.
http://forums.corvetteforum.com/c5-t...m-failure.html
Old Jan 30, 2013 | 12:34 AM
wrmiles's Avatar
wrmiles
If the PCM senses the absence of transfer, after a certain distance driven, it will drive the gauge to zero and give a low fuel message as a warning. I believe the reflash discussed earlier increases the distance before the warning. The true test of an inop transfer is if you run out of fuel and it only takes 12 or so gallons. I had this happen to me because I thought it was the typical gauge behavior due to deposits. Wish there was some way to read each tank separately.
Old Jan 30, 2013 | 01:40 AM
Choreo's Avatar
Choreo
My eyes are burning... just read that entire thread!
So... as I understand, if the computer senses that there is more fuel in the right tank than the left tank while the car is running, the fuel gauge will drop to zero. There are two primary ways that this usually occurs...
(1) The jet pump venturi is clogged or not functioning in the right tank. (no/reduced flow occurs from right to left)
(2) The right tank sensor is reporting the fuel level incorrectly - corroded. (flow may be occurring, but computer does not know that)
Since both of the above items are part of the same assembly, replacing with a new assembly will probably solve either/both issues for a while.
If (1) is the problem - the tank has to be drained and the venturi cleaned or replaced. If (2) is the problem Techron/Seafoam "may" remedy the issue or at least keep it at bay. The frustrating part is that there is no way to know which issue is causing the problem ahead of time unless the engine actually dies - in which case it was probably (1).
Of course all of this is assuming that the left tank sensor is reporting correctly, but that does not seem to be mentioned as often as failing - probably since it is always submerged in fuel - while the right sensor can be exposed to air/gasses whenever gas gauge nears/goes below 1/2 tank.
Choreo,
did you try pulling codes after this problem occurred to see if any PCM codes got set? There are at least a half dozen different codes related to fuel sensors that can get set by the PCM. Perhaps there may be a clue therr that can help???
I am not showing any codes when I run diagnostics
To Another Gas Gauge Zeroed
Old Jan 30, 2013 | 06:42 PM
Choreo's Avatar
Choreo
If the problem occurs again it would be worth pulling the codes BEFORE you shut off the engine to see if anything got set.
Just pulled codes again - I see a History Code now of PCM 1431. I think that is the right sender?
Old Jan 30, 2013 | 07:28 PM
C54ever's Avatar
C54ever
Yes. According to the service manual: This diagnostic tests for a stuck right fuel level sensor signal. If the PCM determines that the right fuel level signal appears to be stuck based on a lack of signal variation expected during normal operation this DTC sets.
Old Jan 30, 2013 | 07:55 PM
Choreo's Avatar
Choreo
So I guess it could still be the sensor or the Jet Pump?
