Traction & activehandling
Old Feb 2, 2013 | 08:06 PM
bzb's Avatar
bzb
Default Traction & activehandling
I'm building a Time trial car out of a C5. Does anyone know how to turn off all the active handling and tracktion control permenently? I've gutted the car and i no longer have the button. If anyone has turned them off and they don't come back on let me know how you did it. I need the ABS so i cann't turn that off. Thanks #5 John
Old Feb 3, 2013 | 11:45 AM
lionelhutz's Avatar
lionelhutz
Holding the button for 4 seconds after you start the car is the only way to disable TC/AH and leave ABS.
Old Feb 3, 2013 | 12:59 PM
Lloyd Christmas's Avatar
Lloyd Christmas
Active handling is still engaged in comp mode. OP, the easiest solution is to see if you can put the button back in. Just plug it back into the harness. If you want abs but no tc/AH, you just push the button once.
To Traction & activehandling
