Column lock problem
Old Feb 4, 2013 | 09:10 AM
DaveP52462's Avatar
DaveP52462
Default Column lock problem
Hi guys,
Just purchased a 1999 from a forum member here.
It has the column lock bypass installed.
He loaded it up on the trailer without any problems.
When unloading at my house we got the "Remove key for 10sec" message along with the "Service Column LocK". We crawled it into my garage as the fuel cuts off if over 2mph.
Upon investigation fuse #23 was blown. Replace fuse and it blows immediately. I"m thinking the column lock motor is shorted.
Any help?
Dave..
Old Feb 4, 2013 | 10:37 AM
thmehr's Avatar
thmehr
Originally Posted by DaveP52462
Hi guys,
Any help?
Dave..
On another recent post about this issue, someone said his wires were damaged inside the column.
Old Feb 4, 2013 | 06:55 PM
DaveP52462's Avatar
DaveP52462
Thank you so much for the detailed explanation.
Well, I found the relay and there is no jumper installed.
I know the PO and he has installed an aftermarket CLB.
There was a short where the purple wire that has a factory splice was making contact with the BCM case. I re-taped it and it no longer blows the fuse. There is no jumper on the relay. Do I need it?
Also the "service vehicle soon" error comes on. I have not driven it yet as I am giving the battery a full charge. Will removing the battery terminals clear all previous codes including the "service veh. soon" error?
Thanks for the response.
Dave..
Old Feb 5, 2013 | 10:38 AM
DaveP52462's Avatar
DaveP52462
Yes, this is my first C5.
Owned a few C3's and C4's over the years.
Dave..
Old Feb 10, 2013 | 11:16 PM
DaveP52462's Avatar
DaveP52462
Well, I removed the relay and added the jumper.
Can't take a test drive as there is 18" of snow outside.
To Column lock problem
