drl removal ?
Old Feb 9, 2013 | 05:28 PM
Ekul61's Avatar
Ekul61
Default drl removal ?
wanting to remove my drl for tinting. does anyone know of a thread explaining how to remove them?
Old Feb 9, 2013 | 07:20 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
If you are talking about removing the front corner lamp housings then look at post #3 in the following thread.
http://forums.corvetteforum.com/c5-t...l-in-here.html
Old Feb 10, 2013 | 02:04 AM
DeeGee's Avatar
DeeGee
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
Old Feb 10, 2013 | 07:09 AM
Ekul61's Avatar
Ekul61
Nice pics thx
Old Feb 10, 2013 | 12:59 PM
Ekul61's Avatar
Ekul61
thx guys. removed them today. went perfect
Old Feb 11, 2013 | 01:19 PM
maxx2200's Avatar
maxx2200
Post pics of the mod when your done.
Old Feb 11, 2013 | 05:37 PM
Ekul61's Avatar
Ekul61
I will max. Doing the vinyl coating in red cherry. I think it will make my yellow pop.
To drl removal ?
