Bump steer kit? Worth the $$ or not?
Old Jun 14, 2002 | 03:31 PM
Moundir's Avatar
Moundir
Default Bump steer kit? Worth the $$ or not?
I just bought the baer bump steer kit, from a fellow forum member, I would like to know is it worth it? Does is really reduce bump steer. My car is lowered and alignmed for max performance, and the bumps on the highways in ny are notorious. Anyone have this kit installed in their car? Does it work? . Also how long does it take to install this kit? Thanx
:chevy
Old Jun 14, 2002 | 05:29 PM
movinup's Avatar
movinup
Default Re: Bump steer kit? Worth the $$ or not? (Moundir)
Gee, I'd like to know the answer to that one also. :yesnod:
Old Jun 14, 2002 | 09:50 PM
MelloYellow's Avatar
MelloYellow
Default Re: Bump steer kit? Worth the $$ or not? (movinup)
I hear you have to be SLAMMED, like 2" lower than stock to need one.
You'd need new shocks before you'd want a bump steer kit.
You running Bilstein Sports?
I'll be measuring my bump steer in about 1.5 weeks.
My front fenders are 26 1/8" with 2/3 of the front bushings cut.
Will measure the up/down toe change during alignment.
Old Jun 15, 2002 | 01:37 AM
Moundir's Avatar
Moundir
Default Re: Bump steer kit? Worth the $$ or not? (MelloYellow)
I am running the bilstein shocks but what do you mean by SLAMMED? Thanx
:cheers:
Old Jun 15, 2002 | 02:20 AM
MDL-01C5's Avatar
MDL-01C5
:cheers:
Slammed= dropped WAY low to the ground-- AKA LOW RYYYDERRRR :smash: :cheers:
MelloYellow
Measure your center fender height from ground to the center bottom edge. What measurements do you have all the way around?
I doubt any of us with leaf springs need a bump steer kit.
Maybe coil overs? I dunno.
Will check mine shortly! I'm about as slammed as you can get up front.
The lowest I've ever heard of is 25.75" F. I'm at 26.125".
Old Jun 16, 2002 | 01:30 AM
Moundir's Avatar
Moundir
I will have to measure it up tom if I can. I hope it does help at least a little. I feel like a jackass for buying this kit without making sure it's right for me :bb
Old Jun 16, 2002 | 12:46 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
How dome you use fender heights instead of frame heights ? :confused:
Old Jun 16, 2002 | 04:28 PM
MelloYellow
Default Re: Bump steer kit? Worth the $$ or not? (MRWHOOPPEE)
Rough estimate, easy to measure.
[Modified by MelloYellow, 3:28 PM 6/16/2002]
Old Jun 16, 2002 | 11:38 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Height will change with tire size. Why did you buy it :bb :bb :bb :bb :bb :bb :bb :bb :bb :bb :bb :lol:
Old Jun 17, 2002 | 01:59 AM
zcobra1's Avatar
zcobra1
Default Re: Bump steer kit? Worth the $$ or not? (John Shiels)
I do not beleive the type of spring has anything to do with bump steer on a car, it has to do with the geometry and the change in geometry as the suspension works. I dont know about everyone else here, but Inoticed some decent bump steer on my stock height 02 C5 as soon as I got it.
I plan on lowering, so I figured it would only get worse if i lowered the car,
correct ??
Old Jun 17, 2002 | 02:52 PM
threeimpalas's Avatar
threeimpalas
You can take tire sidewall height out of the equation by measuring from either the lower lip of the rim, or the center of the hub. If you measure from the hub, then it doesn't matter if you've got 17's, 18's, or 19's.
Old Jun 18, 2002 | 02:31 AM
Moundir's Avatar
Moundir
It was on sale :lol:
To Bump steer kit? Worth the $$ or not?
