Oil Pressure Sender replacement
Old Feb 11, 2013 | 06:43 PM
Jumper11's Avatar
Jumper11
Default Oil Pressure Sender replacement
Well after experiencing the normal C5 stuff, HVAC dim display, fuel gage going to zero and sterring column lock issues I fianlly had the oil pressure gage peg out. Looking at several post concerning the removal and replacement I decided to try it without removing the intake. Wow not much space for my big mitts which forced me to get creative with mechanical fingers, safety wire and a congloberation of screw drivers. It took about an hour to get it out mostly because I had a hard time fishing the sender out once it was out of the hole. It took about 1.5 hours to get it back in. I looked at the intake and thought it would be more difficult. Next time I'll try it with removing the intake. Any guidance would help. Thanks to the forum for all the options.
Old Feb 11, 2013 | 07:03 PM
maxx2200's Avatar
maxx2200
Nice job! You just about got the C5 "to-do" list exhausted. I finally put the relocation kit on mine after the third sender. Here's hoping you don't have to do another OPS (for a while anyway).
Old Feb 12, 2013 | 12:17 AM
Pie R Squared's Avatar
Pie R Squared
Here is the link for taking off the intake manifold. My old sensor fell into the abyss and I have yet to find it. Next time I am removing the intake.
http://forums.corvetteforum.com/c5-t...placement.html
Old Feb 12, 2013 | 08:11 AM
sunchaser73's Avatar
sunchaser73
By the time my OPS crapped out, I had already removed my intake at least twice...so it was a no-brainer. The first time you pull your intake will be the longest and hardest. Gets easier after that.
When I replaced my OPS recently, I used rubber bands to hold the back 2 manifold bolts up and out of the way...made removing the manifold a lot easier! Also, I stuff a paper towel into a zip-loc bag and tape it to the fuel supply tube after disconnecting it, to prevent fuel spillage.
Old Feb 12, 2013 | 06:38 PM
Jumper11's Avatar
Jumper11
My plan was to incorporate the jumper wire Richard from compliance sent me when my OPS went out. I disconnected the battery and pulled the OPS without removing the intake. PITA!!! But the batter was disconnected for 2+ days. Replaced the OPS and reconnected the battery and I no longer get the pull key message. I have everything ready should it return but I can't fix what isn't broken and if I made and changes, I wouldn't know if the old problem returned or the battery being disconnected allowed th BCM to retime. I drove the car today and all worked fine. How a thunk heh!
Old Feb 16, 2013 | 04:37 AM
NotAnExpert's Avatar
NotAnExpert
St. Jude Donor '13
OMG...Thank you...I tried the "intakeless" method and just gave up. The headache was not worth the time.
I have been looking and looking for a how to guide on the intake. You just gave me what I needed to get this done on my next day off. Thanks a tone.
Sorry if I am hijacking
Old Feb 16, 2013 | 04:07 PM
Arnie Chamberlain's Avatar
Arnie Chamberlain
Once you have the coolant tube through the throttle body rerouted, its a 20 minute job to R&R an intake on a C5.
Old Feb 17, 2013 | 07:51 PM
corvettedaddy11's Avatar
corvettedaddy11
Install a catch can to get rid of blow by..!
To Oil Pressure Sender replacement
