fuel rail question
Old Feb 11, 2013 | 06:46 PM
alextz's Avatar
alextz
Default fuel rail question
If I take the feul rails off to change injectors for example, and the fuel rail gets emptied of gas, when I reconnect the fuel line feed, how does air get bled out of the rail? Do you somehow bleed it?
I could see how air could become trapped in the rail
Anybody have any insights?
Alex
Old Feb 11, 2013 | 07:05 PM
rbrtclk's Avatar
rbrtclk
Just reconnect the lines and the fuel pump will get rid of the air. You might have to turn your igition switch off and on a few times.
Old Feb 11, 2013 | 07:12 PM
Cybermind's Avatar
Cybermind
You do not need to do anything out of the ordinary. Just reconnect the lines and start the car normally. The fuel pump will pressurize the fuel system. Air in the system is not an issue.
Old Feb 11, 2013 | 07:13 PM
1999_TRC's Avatar
1999_TRC
The fuel does not get trapped in the rail, so why would the air be trapped?
Old Feb 11, 2013 | 07:51 PM
NukeC5's Avatar
NukeC5
haha, go easy on him. Better to ask then assume and have something go bad right? Yes, just turn the key on and listen to the pump prime a few times.
Old Feb 12, 2013 | 10:23 AM
alextz's Avatar
alextz
So where does the air go? I can see some of it getting expelled through the injectors (causing a sputter).
The stock fuel rails are basicall a cyclinder laid on its side. Can you picture air pockets or bubbles that form on the top part of the cylinder, where even though there is gas coming in, the bubbles kinda remain due to the air pockets/bubbles are lighter than the fluid and thus will always go "up" (the injector orafice is about 1-2 inches below the fuel rail cylinder axis)
Kinda like a hydraulic brake system....there is a reason your brake bleeder screws are at the top of the chamber that houses the fluid in the caliper.....
If bubbles are an issue in a brake system, why arent they a concern in the fuel system.....
Im just looking for a scientific explanation, thats all.
thanks
Alex
Old Feb 12, 2013 | 10:41 AM
NukeC5's Avatar
NukeC5
Its just nothing like a brake system. the air gets pushed into the cylinders probably before the engine even starts (while cranking). The cylinders are filled with air and fuel anyway, so its not going to cause a problem to have this happen for a one split second once in a great while in the life of the engine.
You could try pushing the pressure relive valve if you feel like it will let some out, but its really not a concern.
Old Feb 12, 2013 | 10:52 AM
Patches's Avatar
Patches
Don't sweat it. The air is quickly purged by the pump as you start it. I have changed injectors and had the fuel rail off with no noticeable effect.
http://forums.corvetteforum.com/c5-g...r-upgrade.html
To fuel rail question
