Cam Install Gone Wrong
Old Feb 11, 2013 | 08:56 PM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
Default Cam Install Gone Wrong
May not be a Corvette but, still an LS1. This one had a cam swap and after some time, this happened.
It was really too bad. The owner bought it used and is a really nice guy. He babies the GTO and now has to go through the repair process.
Old Feb 11, 2013 | 09:40 PM
feeder82's Avatar
feeder82
thoughts on a cause?
Old Feb 11, 2013 | 09:44 PM
RealmSteel's Avatar
RealmSteel
Looks like a cam that was NOT heat treated properly.
Last edited by RealmSteel; Feb 11, 2013 at 10:45 PM. Reason: Forgot the word "not"
Old Feb 11, 2013 | 10:12 PM
RonSSNova's Avatar
RonSSNova
What is the point of this post?
Old Feb 11, 2013 | 11:55 PM
96mogt's Avatar
96mogt
Old Feb 12, 2013 | 12:20 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
my guess is a lifter turned and that started the process
Old Feb 12, 2013 | 09:30 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
That would be my guess as well. 3/4 of the lobes are destroyed and one one lifter failed.
Old Feb 12, 2013 | 09:41 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
No point, just showing some pics from a 5.7L and I have not seen a cam with this must damage.
Old Feb 12, 2013 | 12:11 PM
danziger's Avatar
danziger
Although I feel bad for the owner, I love carnage pics. Thanks!
Old Feb 12, 2013 | 12:19 PM
DaveP52462's Avatar
DaveP52462
The point is to learn..
Old Feb 12, 2013 | 01:13 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
To me----When there is that much severe wear on ALL the lobes---It indicates a lubrication issue
--like running out of oil--plugged up oil flow--wrong viscosity---extreme overheating-
Which lifter actually broke ?? I beleive when the oil pressue goes away the 1st lifter to fail is the one that gets the oil LAST in the flow supply
It could be one lifter simply broke 1st and caused all the damage to the rest of the engine--But that would mean you were driving it for quite awhile and it would have been rattling and missing horribly---( I doubt you did that)---
Seems the logical thing is that it was a slow event that ended up finally with a broken lifter and all the other damage had alreday been in progress---
Old Feb 12, 2013 | 02:21 PM
sean.b's Avatar
sean.b
This is just necro car **** without an explanation. I'm about to do a head/cam swap and would like to know how in the hell he managed that so that I dont do it. Looks like he forgot to install an oil pump.
Old Feb 12, 2013 | 02:44 PM
nullpointer's Avatar
nullpointer
Was the car making a lot of noise before it came in ? Wondering how you can tell if the lifter turned before all of this happened.
Old Feb 12, 2013 | 06:04 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Wasn't there a discussion or two, either here and/or on LS1tech, that says step 1 in a cam swap on an LS1 is to install new lifter trays?
Old Feb 13, 2013 | 01:57 PM
drewkeen's Avatar
drewkeen
I see needle bearings in the pan too.
Old Feb 13, 2013 | 01:58 PM
sean.b's Avatar
sean.b
so at minimum a rocker arm went out.. was that what contributed to the rest?
Old Feb 13, 2013 | 02:04 PM
SacCityCorvette's Avatar
SacCityCorvette
Supporting Vendor
From: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Maybe it was coil binding?
Old Feb 13, 2013 | 03:20 PM
C5Natie's Avatar
C5Natie
I had similar damage to my old motor. When a lifter collapses it causes excessive clearance between the rocker and pushrod so it becomes a hammer effect every time the pushrod hits the rocker. That will destroy a rocker really fast, especially a stock one.
Old Feb 13, 2013 | 03:28 PM
3boystoys's Avatar
3boystoys
My father-in-law had an early 80's Camaro. GM has some problems with lifters hanging in their bores. He had a cam lobe ground almost round-car still ran. He had to go to arbitration to get GM to fix what they KNEW was a problem.
To Cam Install Gone Wrong
