Having problems getting the car to turn over, one week it works fine the next it wont turn over. Checked the battery, alternator, starter, and all the fuses related to the body control module and ignition and they all appear to be fine. Any suggestions?
Well it could have gotten wet the other day cause it was raining all day when I was out, and ive recently had a problem with that side leaking due to the removable hard top seal being damaged. I'll check it out and see what I find and get back, thanks for the help.
I literally just had this happen to me so I went to the dic and reset all the codes in a panic bc I was at a local Starbucks and it fixed the issue I’ll wait for problem to reoccur and go from there
