Coolant Temp and RPMs
Old Feb 14, 2013 | 02:19 AM
Bobothree's Avatar
Bobothree
Default Coolant Temp and RPMs
In sixth gear at 70 MPH @ 1500 RPM coolant temp goes to 208-210 degrees. Put it in fifth gear and stay at 70 MPH coolant temp goes to 196-198 degrees. Go back to sixth and temp goes up again. I would like to use sixth gear on the highway for mileage reasons and just stay around 196-198 degrees. I just had new belts, water pump, tensioners, harmonic balancer installed. The problem predates these repairs. Any ideas?
Old Feb 14, 2013 | 03:10 AM
C5Natie's Avatar
C5Natie
The higher rpms in fifth spin the water pump faster hence more flow and temps go down. If youre car is stock 210* is fine and what youre seeing is normal.
Old Feb 14, 2013 | 06:48 AM
65GGvert's Avatar
65GGvert
You don't have a problem.
Old Feb 14, 2013 | 01:32 PM
dadaroo's Avatar
dadaroo
If you have some air in the system then lower rpms may result in higher temps.
Old Feb 14, 2013 | 02:18 PM
SPDKNGG's Avatar
SPDKNGG
Anychance you have a underdrive pulley?
Old Feb 14, 2013 | 02:52 PM
lionelhutz's Avatar
lionelhutz
You could have tell us some other useful information like where you are living and how hot the air temps were.
I've never seen >200*F on the highway, and that is in days up to about 95*F ambient. But it got close to 200*F on those hot days. On the flip side, I see about 191*F on close to freezing days. So, you can guess your expected temps from those numbers.
I'd expect the rad fins are plugged up so the higher rpms moves more coolant and the car is able to use the few fins that are actually flowing air to keep it cool.
Agreed with above, underdrive pulley yes or no?
Also, 210*F really isn't too hot. The car is fine driving at those temps.
Old Feb 17, 2013 | 11:53 AM
toddk's Avatar
toddk
I agree with the others, that it isn't a problem.
I experienced the same temperatures as the OP after doing a H/C project last winter. I also did a thorough cleaning of the radiator while it was all apart. Generally in cooler weather, 40 to 70 degrees, I noted the same temperatures and quick drop when going to 5th. One time I popped the hood and felt the returning radiator hose was cold while the DIC showed 208. Thermostat must have been closed.
I went to a track day around 80 degrees and never saw the temps above 195 on course, just at idle in the pits. I was not in 6th gear much.
Todd
To Coolant Temp and RPMs
