Where is this fluid coming from?
Old Feb 17, 2013 | 02:42 PM
jetning's Avatar
jetning
Default Where is this fluid coming from?
Almost pink fluid coming from the rear. Not all the time. Lifted the car up and nothing seems to be leaking. I did see a rubber tube between the diff and tranny pan. Kinda like an overflow tube of some sort. I think that's where it's coming from. Any ideas? Car is 98 A4.
Old Feb 17, 2013 | 03:12 PM
corvette77's Avatar
corvette77
If it is a pink colored fluid, it just about has to be transmission fluid.
Old Feb 17, 2013 | 03:37 PM
jetning's Avatar
jetning
What about the rubber tube between the pan and diff?
Old Feb 17, 2013 | 06:37 PM
C5FORFUN2's Avatar
C5FORFUN2
It looks to me like it is a vent for the trans. Just finished a filter and fluid change on my A4 and the hose comes from somewhere on top of the trans then "T"s to a check valve and continues down to the front of the differential. Mine was also getting some fluid from there and would drip once in a while. Hopefully the trans was just a little over full and now that it is at the correct level it will stop.
Old Feb 17, 2013 | 08:26 PM
corvette77's Avatar
corvette77
I am going to have to go with C5FORFUN2 on this one, since mine is a manual and I don't remember seeing any hoses coming off mine when I changed the fluid. That being said, did you recently change your fluid?
Old Feb 18, 2013 | 09:19 PM
C5FORFUN2's Avatar
C5FORFUN2
Gave it a good work out today and no leakage from the vent tube anymore. So I think it was just a little over filled before. I also extended the vent tube down to where it's actually touching the ground ( need to shorten it or let it wear off) But at least if it vents some fluid it won't end up on the front of the diff.
Old Feb 19, 2013 | 12:08 PM
jetning's Avatar
jetning
Thanks for the info. I don't have to worry about it now.
To Where is this fluid coming from?
