Stinger install
Old Jun 15, 2002 | 01:55 PM
mmorse's Avatar
mmorse
Default Stinger install
Just got back from a muffler shop. I wanted them to install a Stinger system on my Z06 and they said the only way to get the stock mufflers off was to cut them. I want them left intact. Do you have to drop the rear suspension to get the stock mufflers off without cutting? At the price GM wants for TI mufflers, there's no way I'm going to cut them.
Old Jun 15, 2002 | 01:59 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Stinger install (mmorse)
I understand if you drop the sway bar you can get them out...I cut mine.
Old Jun 15, 2002 | 02:20 PM
HGlide82's Avatar
HGlide82
Default Re: Stinger install (pewter99)
You don't have to cut them, just unbolt the 2 bolts on each side of the rear sway bar and rotate it down. The exhaust will come right out after you do this.
Old Jun 15, 2002 | 02:25 PM
mmorse's Avatar
mmorse
Default Re: Stinger install (HGlide82)
Thanks guys
Old Jun 15, 2002 | 02:27 PM
mmorse's Avatar
mmorse
Can this be done on jack stands or does the car need to be on a lift? In other words, do you need alot of vertical clearance to manuever the mufflers? Thanks
[Modified by mmorse, 10:27 AM 6/15/2002]
Old Jun 15, 2002 | 02:41 PM
Sam Lin's Avatar
Sam Lin
To clear the exhaust swinging down without cutting, you need at least 3 feet of under-car clearance.
Sam
Old Jun 15, 2002 | 03:11 PM
pewter99's Avatar
pewter99
Default Re: Stinger install (Sam Lin)
Sam
:yesnod:
To Stinger install
