What else should I consider while I'm in there.
Old Feb 21, 2013 | 09:11 PM
bracketshark's Avatar
bracketshark
Default What else should I consider while I'm in there.
I'm fixing to do a head & cam change on my 99frc. the parts i already have are: 243 heads fresh from AI with new springs and titanium retainers and their CNC port job, I also got the head gaskets, new lifter, lifter retainers, and new comp rocker bearings and their suggested cam. I've also got a "new" Tony Mamo ported fast 90 and TB with the wiring connectors. I have a new lower ls6 PCV style intake cover to install also. My used long tube headers are in nashville getting coated as i'm writing this. I know I need a new timing set, probably a new Rollmaster will be my choice, My car runs great oil pressure, I think i'll reuse the oil pump. I guess I'll figure out which push rods it needs after every thing is back together. And last but not least I have a new set of MSD wires (need plugs though). Have I missed anything? I'm looking for 415-430 RWHP
Old Feb 21, 2013 | 09:45 PM
PhysicsDude55's Avatar
PhysicsDude55
Spark plugs. I figure you probably just forgot to mention them though....
Old Feb 21, 2013 | 10:31 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
While you have the intake off I would relocate the oil sender, by installing a oil sender relocation kit that several of the vendors on this board sell. There are also several threads on making your own kit.
Old Feb 22, 2013 | 02:20 AM
RonSSNova's Avatar
RonSSNova
Knibling pins.....
Old Feb 22, 2013 | 08:41 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
ATI balancer and pin the crank.
Old Feb 22, 2013 | 11:26 AM
bracketshark
Originally Posted by RonSSNova
Knibling pins.....
WTF? I didn't ask for that, you can "stick" that knibling pin, and I hope its a big one..
I forgot to add I have a 10% underdrive ATI balancer With new gatorback belts, and the ATI pin kit. Hum just thought about it, might as well get 2 new belt tensioners and a new idler pulley while I'm @ it.
Old Feb 22, 2013 | 12:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!!
- Roller Rocker Trunion Up-grades. The improved trunions are very high quality and a big improvement over stock!
- Rocker Trunion perches. They can and do wear and cause rocker geomerty inconnisitys. Carefully examine the area where each rocker sits in the perch and if there is wear/slop,, replace them. They are only a few bucke each..
- ARP Head studs. Once you install and use this,, you will ask your self, WHY,,, did I wait so long to do this improvement???
- ARP Damper Bolt. Same comment as the one above!!
- MAP Sensor Reloaction Kit! Same comment as the one above!!:cheers
Bill
Old Feb 23, 2013 | 08:50 AM
bracketshark
Thanks for the replies..
Originally Posted by Bill Curlee
YES!!
- Roller Rocker Trunion Up-grades. The improved trunions are very high quality and a big improvement over stock! Got Them From AI (Advanced Induction)
- Rocker Trunion perches. They can and do wear and cause rocker geomerty inconnisitys. Carefully examine the area where each rocker sits in the perch and if there is wear/slop,, replace them. They are only a few bucke each.. I'll check on these
- ARP Head studs. Once you install and use this,, you will ask your self, WHY,,, did I wait so long to do this improvement???I've got these
Got this also
- MAP Sensor Reloaction Kit! Same comment as the one above!!:cheers Yes gonna do this mod, i've got my own fix in mind if it works i'll share it.
Bill
Old Feb 23, 2013 | 08:53 AM
bracketshark
Thanks for reminding me, I'll be doing this also.....
Old Feb 23, 2013 | 10:56 AM
RonSSNova's Avatar
RonSSNova
[QUOTE=bracketshark;1583190091]WTF? I didn't ask for that, you can "stick" that knibling pin, and I hope its a big one..
QUOTE]
Chill, it was a joke.
To What else should I consider while I'm in there.
