What is the current LS1 crate engine replacement?
Does anyone know what the official GM Goodwrench replacement engine is for the LS1? It has to be the factory recommended replacement crate engine to be legal to compete.
I've got a modified engine with 214K on the clock. Top end is fresh (@190K), but the rotating assembly is original. 412 to the tires...
The weakest link in the stock motor is the valve springs.
edit: As stated before the valve springs are the "weakest" link, but that's usually only a problem for track events.
I wasn't planning on replacing the engine so much as I was wanting to see if there were any newer parts on it that might give me a few extra horses. For example, I understand that after 2000, all LS1's switched to the LS6 manifold. I assume that's the main reason the latest LS1 crate motor is rated at 350/365 while my motor's rated at 345/350. While 5 peak hp isn't much, 15 ft/lbs of torque is huge - it's enough to make the car feel like it's being driven by a jockey instead of my 250 lb behind.
I've also got a steep learning curve ahead of me on the suspension upgrades. I was a pretty serious drag racer for about 10 years, so I know about engines, rotating weight, and such, but not so much about suspension setup.
I also replaced a bunch of gaskets, the damper (mine had the wobble), both of the tensioners, fluids, belts... since the motor was apart. In hindsight, I should have had the 243 heads worked over before I put them on, but the bills were climbing higher than expected.
Go to the Autocross /roadrace section for more input also.
Glen aka MeHurricane
That's why I'm asking. I'm not averse to gray areas, but I don't want to stray into the black. What is the rule for a replacement engine? From what I read on the SCCA website, a replacement engine has to be the factory recommended part for that year of car, in this case the GM Goodwrench engine, and specifically NOT a GM Performance Parts only engine, unless that is the general replacement recommended by the factory. Is that correct, or did I read that wrong?
I HAVE to replace the valve springs, I can hear valve float, and the balancer is wobbling so I'm going to replace that. I'm not going to upgrade the injectors, but I am going to buy a set of flow matched stockers to keep the computer from adding fuel or pulling timing at full throttle. Most of this stuff is the kind of thing you do in drag racing when you're racing in a stock class. I'm not so much interested in making big gains in hp as I am in minimizing the losses. The LS6 intake would be an exception in this area, since it is presumably the main reason for the torque increase in the goodwrench LS1 motor. If I ordered a replacement intake from the factory for a 2000 LS1, would GM send me the earlier LS1 intake or the improved LS6 intake as the stock replacement? If the latter, doesn't that make it legal for competition?
As far as your recommendations on seat time and suspension, I hear you. I'm taking a beginners' class at Dallas Raceway next weekend. I'm going to run the car in daily driver trim for the first half of the season at least, until my budget will allow me to upgrade to DOT race tires and something like the Penske double adjustable shocks. I don't expect to be competitive above a regional level this year, and probably not even that; however, it's not as much fun if you're not trying as hard as you can.
