exhaust cut outs C5
Old Feb 28, 2013 | 02:18 PM
doug doo wop's Avatar
doug doo wop
Default exhaust cut outs C5
Does anyone have exhaust cut-outs on their C5? My '02 stock engine has the Corsa Extreme exhaust and it's quieter than my other middle Corsa(pace or touring?). When I put the other Corsa on my '04, it's loud and sounds great at idle;I don't understand that. I know the C6 has that mild to wild but what about the C5? Thanks
Old Feb 28, 2013 | 02:57 PM
BlueDevil03's Avatar
BlueDevil03
4th Gear
I have the loud mouth slp exhaust with bassani x pipe and im super happy with the sound and performance. I had the borla on it previously and it just wasnt the great sound i wanted at idle. I have recently installed long tubes on it so its insane loud and love it. But if u want some good electrical cut outs go to quicktime performance. I have a down pipe with electrical cut out on my srt4 and love it. They offet electrical cut outs for corvettes as well.
Old Feb 28, 2013 | 04:08 PM
Patches's Avatar
Patches
Get the ovals if you do go this path. The ovals are nice with their lower profile - unfortunately, they weren't available at the time I installed mine.
I did a lot of planniing and measuring when I installed my round QTP cutouts. I had a set of Y-pipes that were part of my FLP headers that ended up not working with the electric cutouts. The Y-pipes were meant to be capped/uncapped manually so they fit in the larger, forward section of the torque-tube tunnel. It was a no-go with the QTP's though - not nearly enough room to do the Y-pipes with QTP's. So, I ended up installing them just before the over-axle pipe flanges and that worked out nicely.
A non-starter - Y-pipe trial fit
I modeled them up in CAD first to try different positions and then had an exhaust shop weld the flanges in.
Actuator switch
Custom ashtray replacement I designed and had machined from Delrin
There was a forum member (and vendor, IIRC) who welded a set into his Z06 Ti catback.
To exhaust cut outs C5
