I have a pinning tool which is a metric bolt with a custom machined disc with a 1/4" drill bushing pressed in. The bushing is centered on the interface between the pulley hub ID and crank snout OD. The tool is installed, a 1/4" hole drilled and a 1/4 dowel tapped in to keep the pulley from spinning on the crank. I use two dowels 180 deg. apart to try and keep the balance as neutral as possible.
I forgot to ask before I bought the damn thing but should I use the steel ATI balancer or the aluminum/steel ATI balancer? I ordered the aluminum/steel one but if I have to I can just send it back for an exchange since I won't be having the car worked on until the 18th. Thanks again.
That is friggin cool. I wonder though, how would it work on an aluminum pulley? Would the bit try to walk toward the pulley as you got farther in? I have another engine where I feel the stock keyway is inadequate and I believe now that this is the answer. Might be a good question for the OP as he's stated that he purchased the aluminum version of the ATI.
I've seen these done on AL pullies - no difference. The drill bushing keeps you straight as along as you don't push the drill sideways. You could make an intermediate bushing inside the 1/4" bushing to create a pilot hole if you had that concern also. These types of pinning tools are usually included with supercharger kits where it's a must to pin the pulley to the crank. I believe this one is from ATI. I drew it up in AutoCAD to document it once in case I ever lost this one.
I personally don't plan on having mine pinned as I don't foresee anything such as a blower anywhere in the future. Is it even needed for someone who will be making bolt on power at most for the distant future? Don't have any grand plans for forced induction. But the information would be good for anyone planning on going that route.
I have heard of spun pullies on both FI and stock motors. Heck, the 2005 C6 had the same problem when they first released it and none of those cars were blown. C6 was a slightly different config with a friction washer between the pully hub rear face and crank shoulder.
I did it because 1) I had the tool and it's a 10 minute job and 2) better safe than sorry. I was in there anyway so what the hey. Nothing more frustrating than doing a job this involved and later regretting skipping a step that could have prevented a failure.
Most stock C5's never experience this problem but some do. Plus, I put a new pulley on there and the chances of that one slipping are probably higher than a factory-installed pulley where everything was closer to nominal and new when it was installed.
I may take a closer look at pinning it than I did before. Any input on the aluminum/steel vs steel option?
I pinned mine, NA car. Just made sense to me. I used the ATI pin kit that puts a pin in the side of the crank snout instead of the end. The pin then uses the key way in the balancer.
The end method seems like it would be really hard if not impossible to re-align if you ever had to R&R the balancer.
There is so little material removed, I would drill two more holes 90 deg. to the first set. The chances of me having to do this again are pretty low and a second set of holes and pins would not be a big deal - symmetry would still be maintained for balance. Curious, how would you line up a new HB with your setup? Is there a blind hole in the side of the snout?
I've been doing a LOT of research on this topic, as I don't like the idea of a ticking time bomb hanging off the front of my engine. Having said this, I've sent out several e-mails to the various harmonic damper manufacturers, and they all said that the orientation of the damper on the crank doesn't matter.
In essence, the keyslots they put on their dampers are primarily for aftermarket cranks that have provisions for keys. However, as most of us know, A&A supercharging and ATI both make "pinning kits" for use with stock cranks. ATI has two pinning fixtures. One simply places a pin location that's clocked anywhere on the end of the crank. The other requires removal of the timing cover and oil pump to place it, but then it locates on the key that drives the oil pump, and locates the damper pin in line with this key. The advantage is that you can remove the oil pump without having to remove the pin.
It was interesting. The hole goes all the way through to the balancer bolt. The hole is reamed and the pin is an interference fit.
If I were to do it again, I'd use the kit that indexes off the cam gear key so the pin is aligned with that key. Then you could remove the cam gear w/o pushing the pin out.
Obviously, you can't use this method on a stock balancer.
Thanks for the explanation and pic. I would use the cam gear key indexing method as well for the next round - especially on a modded setup. This was a stock repair - I doubt I'll mess with again. (I hope!)
Ron
Ron, since you've alreay attacked this job, while I'm still "researching" (procrastinating), is it safe to assume that it's not possible to get your head in front of the engine, to look through the front cover, and line up the "short" ATI fixture, so it's in line with the oil pump drive key?
My reasoning would be to put the pin where you could still get the oil pump and/or crank gear off w/o removing the pin, but being able to do the job, w/o having to pull the front of the engine apart.
Boy, I don't know. Would be real difficult with the cover on and the oil pump on. Maybe. Butyou would have to figure out a way to precisley align the fixture with the key. I wasn't thinking when I did mine (I had everything apart) and the description for the ATI tool for use with a distributor was confusing. Didn't even dawn on me to align the two until I had the pin in and went to put the crank gear on....oops!
Fortunately, you just knock the pin on through and put it back in.
