wheel spacers
Old Feb 28, 2013 | 11:19 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Default wheel spacers
I have some stock c6 wheels coming and am trying to figure out what to do about the offset situation in the rear. I've done a search, read a bunch and still don't have the answer. here's what I want to know:
-if I just use 1/4 inch spacers, do I need hubcentric ones?
-if I use 1/4 inch spacers, do I need new lug nuts?
-if I want to use 1/2 inch spacers, what do I need? hub centric spacers and longer bolts?
-can I R&R lug bolts without removing anything else from the car?
Old Mar 1, 2013 | 07:57 AM
AU N EGL's Avatar
AU N EGL
longer ARP studs would be a good option. Plus Hardened lug nuts.
any spacer needs or should have longer studs.
Old Mar 1, 2013 | 09:21 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
thanks for the info.
I did some more reading and decided to go with a 1/4' spacer and the extended lug nuts. seems good but I wont be able to drive it until the snow goes away
To wheel spacers
