Horn
Old Mar 3, 2013 | 01:41 PM
50thZ's Avatar
50thZ
Default Horn
So, the fuse is not blown and the relay has been replaced and clicks with both the key pad and wheel. Should I check anything else before pulling the car apart the check the horns. I don't have a very easy way to lift it where i am.
Thank you for your response.
Old Mar 3, 2013 | 01:59 PM
bighank's Avatar
bighank
Default Had one bad horn but I suspect the wiring
Had one of the 2 horns dead. If both are not functioning I would suspect the wiring.
Get to them by jacking up the front, putting some jackstands (never trust a jack), and removing a few screws holding the paper like splash shields under the horns. They are on the passenger side to the right of center.
Old Mar 4, 2013 | 04:53 AM
PierEagle's Avatar
PierEagle
The wire connections get groady under the car. Pull the connectors at the horn, clean the contacts, male and female with a little steel wool or fine sandpaper, spray a little WD40 and reconnect. Been there, done that.
To Horn
