I have a 99' corvette and ive been having some electrical issues ive went over all the grounds and everything i had taken it to a corvette specialist and he was saying its the EBCM question is the EBCM on my car on the top says ABS-5/TCS/MSVA/AH the one i was just recently given and has not yet been installed on the car says ABS-5-TCS/AH are these parts going to correspond if i take out the old one and put this one in will it be more problematic because it could be the wrong on or is it safe to use
Huh? longest run-on sentence I've seen in quite some time.
the codes are:
TCS-C1255 H
58-SDM U1016 H
B0-RFA U1096H
B0-RFA U1064H
B0-RFA U1016H
The EBCM thats in the car now read:
ABS-5/TCS/MSVA/AH
DELPHI D
Model:09356971
The One i just recently got reads:
ABS-5-TCS/AH
Delphi Delco electronics systems
Model:09360921
my car is a 1999 with its stock EBCM was told to switch it out and this is what i was given.i was told this EBCM i purchased came directly from another 99' and was told it would work but i have a feeling that he was incorrect. Any info or thought would be much appreciated thank you
So pretty much the ebcm I was sold is wrong an can't be used in my car I'm new to the whole electrical part of the corvette system so any info is a big help
Both of EBCM the one in the car an the one I have picked up both have the "AH" on them but the EBCM that is in the car also says MSVA where as the one I have not installed nor do I think I will install is missing the MSVA what exactly is that
